Old 03-23-2008, 08:13 PM
Malitude Malitude is offline
Default Flywheel Casting Numbers
Happy Easter!
Well, I have gone through the car to chack all of the numbers. Everything is numbers matching. I don't have any info on flywheels so I can't check these numbers. I have 2 flywheels and was wondering if anybody could tell me what they are for?
Casting number 3789738 date code B179 (Feb 17/69)
Casting number 3791021 date code C49 (Mar 04/69)
The car was ordered in Feb '69 and the original owner took delivery of it in April '69. Pretty much everything was casted in March. I did receive a 283 that was in the car which is now removed. Which flywheel is for this motor? The 3791021 casting has been balanced and is much thicker than the other.
Also, is there casting numbers on starters? If I give you guys the number off of the starter, could you check that as well?
Thanks in advance!
Rob
Old 03-23-2008, 08:42 PM
Default Re: Flywheel Casting Numbers
The #738 was used on earlier model Series 10-20 Trucks w/SB.
The #021 cast was originally used on & recommended replacement for M/T equipped vehicles up until 1970,on:
*1970 ALL vehicles w/307cid & 6cyl.
*1969 Passenger 327cid & 350cid.
*1967-69 302cid.
*1964-69 ALL w/230cid & 250cid.
*1964-68 ALL 283cid & 307cid & 327cid.
*1962-69 Chevy II & Chevelle w/HD clutch.
*1963-68 Passenger & Corvette w/283cid & 307cid.
Starters have a part number and date code stamped on the outside of the housing,just below the solenoid.If you relay it,I can check it for you.
Old 03-24-2008, 05:57 AM
Thanks mr70. The number that I found on the starter is 1108237 and it has 1E3 and 2E5 under it.
Rob
Old 03-24-2008, 08:05 AM
68SSCamaro 68SSCamaro is offline
Are you sure on the 3789738? Is it 3789733?
Martin Foltz
68 Camaro SS-396
L35/M20, Corvette Bronze, black vinyl top
George Olsen Chevrolet San Francisco
Old 03-25-2008, 02:59 AM
FRITO FRITO is offline
Default help
would alyea i tried that on the tag under hood by the brake booster has som numbers and letters like st 69 wrn11427 lower down it has a 53 53 by what i think is the trim this car has a metal plate were my other nova had a radio strange huh it also has this gills like fish gills on the fenders whats l this mean
GOT A NOVA NEED INFO PLEZZ
Old 03-26-2008, 12:47 PM
Default Re: help here is more info plezz help me get start
hey you guys can u help me i got a new project nova JUST GENRAL INFO LIKE WHAT IT WAS FACTORY I TRADED MY BOSS LADY CADDY FOR IT IT HAS A TAG ON FIRE WALL SAYS ST 69 WRN 11427 THERE IS A 53 53 BELOW THAT ON THE INSIDE IT HAS A PLATE WERE THE RADIO WAS ON MY OTHER NOVA HAS 12 BOLTS IN THE REAR COVER OF REAR END TRANNY WAS IN THE TRUNK HAS A TAG THAT IS STAMPED CY -69 ON THE DRIVERS SIDE OF TRANNY IT CAME WITH A BIG BLOCK ON A STAND SOPOSSED TO BE THE ORIGANAL MOTOR AND IT HAS GILLS ON THE SIDE LIKE A FISH tho motor has a casting number 3963512on the back driver side
head has acasting number of 3946074 alumunim has the factory intake its ulumunim and has funny lil snow flake casting on it does this help i hpoe its worth tho caddy i trade
Old 03-26-2008, 04:14 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Alright is this guy for real or is he just messing around posting jibberish in a bunch of different posts.
Old 03-26-2008, 04:59 PM
rubbinisracing rubbinisracing is offline
FRITO....we ain't bitin!
Technical questions such as yours are probably better left to the experts. Please send a SASE to your friends Bill, Jeff, Ron & Larry for their opinions.
Hope you find this helpful!
Howard
Growing old is a certainty, growing up isn't
Old 03-26-2008, 05:14 PM
As I said before..."Mr. Lay" www.novas.net is where you need to go for your answers...
Old 03-26-2008, 05:42 PM
Chateau Slate 66 Chateau Slate 66 is offline
I am going to have to wave the flag...
I don't believe that a guy can figure out how to join a site,then cut and paste his "question" into several different forums, but does not understand basic forum etiquette even after being nicely asked to start his own thread.
I also believe that even if someone does not type well, they can read back what they wrote and realize it is barely comprehendible.
