I have an Endura bumper that I was hoping could be restored - overall in good shape outside of a bad paint job and a split (3rd photo) on the bottom underside. Any thoughts on who could restore the bumper if it can be?
thanks in advance - Jeff ![]() ![]() ![]()
The VE3 bumper consists of a steel liner with rubber molded over it. The bumper is not watertight, the liner is not coated and rusts over time, splitting the rubber as seen in the photo. In my parts days we had a few so rusted they were limp. I have seen attempts made to repair them but they look repaired and continue to blister.
Grind all the paint off with 80 grit. I would then cut a flap that fully exposes the rusted area. Grind the rust away and prep it properly and then use the 2-part urethane rubber bumper repair stuff as a glue to hold the flap back down and clamp it in place.
I have done the same with Cuda rubber bumpers. They all had a habit of breaking off the sealed-in bumper bolts and you had to do similar surgery to replace the bolts. |
McGyver... is there anything you don't know how to fix?
OBTW.. I am having problems with my Illudium P36 Space Modulator... can you help me?
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
Thats a low and slow pitch over the plate...The Illudium P36 Space Modulator can be recailibrated just like an old GM points distributor. Grab an old match book and gap the Grepton dialubic flange to .019 and it should work just like new. Send me a postcard from Mars, and say Hi to Marvin when you're there!
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
What about soaking the bumper in Safest rust remover?
Unless you cut the access flaps, it wont be able to get to the rusty area. But its a good idea if it can reach the rust.
Thanks for all the feedback and suggestions -
Thats a low and slow pitch over the plate...The Illudium P36 Space Modulator can be recailibrated just like an old GM points distributor. Grab an old match book and gap the Grepton dialubic flange to .019 and it should work just like new. Send me a postcard from Mars, and say Hi to Marvin when you're there! ![]() [/ QUOTE ] That was great! I rarely comment on these but this one was classic! ![]()
Chavez Ravine |
Thread Tools | |
Display Modes | |
