Old 12-31-2010, 05:03 AM
Default Best lubrication - seized manifold bolts
Would someone please post (again) a list of best lubricants. It was a best to worst list based on torque required to break the bolt free. It included wd40, pb blaster and a bunch of other concoctions.
Thank you [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Old 12-31-2010, 05:33 AM
resto4u resto4u is offline
Default Re: Best lubrication - seized manifold bolts
Kroil, pb blaster, wd-40
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 12-31-2010, 06:08 AM
Someone once told me that the best stuff is not even made. Testing was done and I would love to have some real world testing by someone that I know. The witches brew is a half and half mixture of acetone and ATF. Someone willing to try?
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 12-31-2010, 06:26 AM
Mr. Chevy's Avatar
Sam, Power Blaster always worked for me but it's not always a 100% remedy... Saturate the bolts/area and let it sit overnight and then try it..
OR
I'm not sure which manifold bolts you are referring to.. But
you could try putting a little heat on them.. Just have to be sure you don't snap em' off when screwing them out, GO SLOW.... Then it's drill out time!!! Been there done that.... [img]<<GRAEMLIN_URL>>/no.gif[/img]
Rich
Old 12-31-2010, 04:56 PM
If exhaust manifolds to head bolts, depending on what engine sometimes it's better to torch the heads off and slip the manifolds off over the bolt..
With the manifold off you can access the head with heat and using grips or good quality battery pliers on the protruding stud and heat where they thread into the head they can easily turn out and a whole lot better than playing stud extraction games w/ broken bolts..
If flange bolts, heat your nuts!.
Anyone here ever try the candle wax trick?.
Good luck!.
Old 12-31-2010, 05:09 PM
67 Nova Boy's Avatar
Kroil works very well!!
Dave
67 Nova Boy
Old 12-31-2010, 05:20 PM
SS427's Avatar
SS427 SS427 is offline
I use the candle wax method all the time and it works pretty damn nice. Ever try getting a steal heater hose fitting out of an aluminum intake? I could never get it out without cracking the aluminum until I tried the candle wax and it worked great. Now I use it all the time.
Rick Nelson
Old 12-31-2010, 05:21 PM
Rick just likes playing with fire.... [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 12-31-2010, 05:37 PM
Thanks all. Rick can you elaborate on the candle wax method? [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 12-31-2010, 05:49 PM
ORIGLS6 ORIGLS6 is offline
I recall the candle method from years ago but I've forgotten the procedure. Heat the surrounding area for expansion from the bolt, then hold a candle or stick of paraffin next to the bolt? Kinda like sweating copper pipe? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Seems like the list you're asking about included Kroil near the top but like Rusty says their &quot;Best Method&quot; was acetone and ATF. Also (again, going on an old guys memory) they put good old Liquid Wrench near the top, especially considering cost/oz.
