Old 11-18-2011, 07:13 PM
flyingn's Avatar
flyingn flyingn is offline
Default 2013 GT500 most powerful OEM v8 in the WORLD
2013 Ford Shelby GT500 Debuts As Most Powerful Production V8 in the World with 650 Horsepower, Top Speed of 200+ MPH
New Ford Shelby GT500 is powered by an aluminum 5.8-liter supercharged V8 producing 650 horsepower and 600 lb.-ft. of torque, making it the most powerful production V8 engine in the world
Nearly every vehicle system has been optimized including powertrain, brakes, gearing and suspension
New Shelby GT500 sets a performance-driven design standard with new downforce- generating front grilles, aggressive splitter, new quad exhaust system and two new forged-aluminum wheels
Also new for 2013 is an optional Performance Package with SVT-designed Bilstein electronic adjustable dampers and a Torsen limited-slip differential. The offering can be coupled with a track package for all-out racetrack performance
LOS ANGELES, Nov. 15, 2011 – The ultimate Ford Mustang – Shelby GT500 – raises the bar high on performance with the introduction of the new 2013 model that goes on sale next year delivering 650 horsepower and a top speed of more than 200 mph.
“SVT keeps the Shelby GT500 on the cutting edge of technology and takes muscle car performance to new heights,” said Jost Capito, director of Global Performance Vehicles and Motorsport Business Development. “We encapsulated every aspect of performance in this car – whether it’s 0-60, top speed, racetrack or quarter-mile times. Beyond that, the daily driver also will find this car perfectly fits his or her needs.”
The 5.8-liter V8 aluminum-block engine produces 650 horsepower and 600 lb.-ft. of torque, making it the most powerful production V8 in the world. The 3,850-pound car also stays exempt from the gas-guzzler tax.
Nearly every part of the powertrain has been optimized for producing the additional horsepower, including a new supercharger, new cross-drilled block and heads, updated camshaft profiles, a new carbon fiber driveshaft and upgraded clutch, transmission and axle.
A larger, more-efficient supercharger flowing more air through the engine is key to helping produce the massive 650 horsepower. The new TVS series 2300 creates 2.3 liters of displacement and is a unique design to the 5.8-liter engine.
The entire cooling system has been significantly updated on the new 5.8-liter engine. It now includes a larger cooling fan, fan shroud with high-speed pressure-relief doors, a more efficient charge air cooler, a higher-flow intercooler pump and an intercooler heat exchanger with volume increased 36 percent.
Revised gearing
Nearly every gear on the 2013 Ford Shelby GT500 was revised to manage the torque and use more of the power in a way that makes it more driver-friendly. Engineers considered more than 35 gearing combinations, finally deciding on one that delivers less torque all the way through the wheels to the ground and still enables the car to achieve fuel economy targets.
A key piece of the driveline, the six-speed manual transmission, offers upgraded gears, bearings and housing so it can properly manage the torque. The final drive ratio is now 3.31:1 for optimized overall vehicle gearing to complement the massive torque. Every gear besides fourth was optimized for competing performance metrics. The clutch has increased torque and rpm capacity and uses a dual-disc design.
“It might just seem like we’re putting a bigger engine into the car. But it’s been a balanced approach through and through,” said Jamal Hameedi, SVT chief engineer. “We’ve completely redone the car to be even more sophisticated in terms of handling and control than the prior model.”
Other keys for improved traction management include:
Torsen limited-slip differential:When customers order the optional Performance Package, they will get a Torsen limited-slip differential that helps the rear suspension deliver maximum torque and traction better and longer under track conditions
Launch control: A new launch control system lets drivers set the desired launch rpm depending on tire temperature, street surface or other conditions. Unique to SVT’s launch control is that it is integrated with both the engine control and traction control
Brembo braking system: A new Brembo brake system offers drivers enhanced stopping power to help keep their car under control, both on the road and the track. New six-piston calipers in front along with larger front and rear rotors help improve brake fade. New brake pads that are more aggressive also help the car achieve high deceleration and further robustness for more driver confidence
Aero advancements
Significant aerodynamic work was done on the new Shelby GT500 to ensure the car has proper downforce for optimum performance at all speeds. Engineers were able to determine how to harness the air that was moving around and through the car to improve the cooling system, maximize downforce and minimize drag.
The front fascia and splitters were modified to handle the extreme loads at 200 mph, resulting in a car that tracks more securely and feels more planted to the road at higher speeds. It offers 33 percent more effective aero loading at 160 mph compared to the 2011 model.
Superior ride
The new Shelby GT500’s driving dynamics have been improved, now working in concert with all the new content on the car.
Handling, all AdvanceTrac settings and steering assist levels within selectable steering have been tuned to account for the updated content. The previously available unique traction control system and electronic stability control settings help drivers achieve maximum performance on both the street and the track.
Both systems can be completely disabled in controlled track situations where maximum driver skill is utilized, or fully engaged for maximum safety during normal driving or in less-than-ideal traction conditions. Intermediate sport mode allows drivers to push their cars hard at the track without completely disabling the safety systems, permitting more aggressive driving before the traction control and electronic stability control intervene.
“We took a completely different approach with this car so drivers can choose their settings instead of a computer making the selection,” Hameedi said. “Nearly every system the driver interacts with can be tailored to his or her situation including the Bilstein electronic adjustable suspension, launch control, AdvanceTrac and steering assist levels.”
The 2013 Shelby GT500 offers two new sets of forged-aluminum wheels including a unique wheel for cars with the optional packages. The 19-inch front and 20-inch rear wheels are coupled with Goodyear Eagle® F1 SuperCar G: 2 tires on all vehicle configurations.
Taking it one step further
Sometimes Ford Shelby GT500 customers want to enjoy their car on surface streets. Other times they just want to let loose on the track. Two new optional packages on the 2013 model give them the choice.
Available as part of the optional Performance Package, SVT-designed Bilstein electronic adjustable dampers are accessed on the dash with a simple push of a button. Normal mode gives customers a more comfortable ride over road irregularities. Sport mode is all about performance, delivering improved response time on the track and less body roll while cornering and pitch under braking. The Torsen limited-slip differential also comes with the Performance Package.
“The adjustable shocks let us develop our car on the track without any compromise,” said Kerry Baldori, Ford SVT Global Performance Vehicles chief engineer. “Before, we had to tune the car with street implications in mind. Now we can go as extreme as we want on the track setting and still offer the customer a comfortable ride on the road.”
Enthusiasts can upgrade their Performance Package with an additional Track Package for all-out performance. The option comes with an external engine oil cooler, rear differential cooler and transmission cooler for further durability. The coolers play an essential role in preventing crucial components from overheating under high-speed conditions.
The 2013 Ford Shelby GT500 will be built at AutoAlliance International Plant in Flat Rock, Mich.
About Ford Motor Company
Ford Motor Company, a global automotive industry leader based in Dearborn, Mich., manufactures or distributes automobiles across six continents. With about 166,000 employees and about 70 plants worldwide, the company’s automotive brands include Ford and Lincoln. The company provides financial services through Ford Motor Credit Company. For more information regarding Ford’s products, please visit www.ford.com.
Frank Szymkowski
Old 11-18-2011, 09:09 PM
Default Re: 2013 GT500 most powerful OEM v8 in the WORLD
Awesome.
1968 Camaro Ex-ISCA Show Car
John 10:30
Old 11-19-2011, 01:31 AM
old5.0 old5.0 is offline
Is that 5.8 a poked 5.4 Mod, or is it based on one of the new engines? Nothing I've read has explained that yet.
Old 11-19-2011, 03:41 AM
flyingn's Avatar
its a bored and stroked 5.4. 351 cubes.. (think boss 351 for next year)
Frank Szymkowski
Old 11-20-2011, 07:33 PM
427TJ's Avatar
427TJ 427TJ is offline
Nice to see the horsepower war is still underway! Now GM and Mopar will have to respond!
Old 11-21-2011, 12:00 AM
XXXGoldL34M20's Avatar
Nice to see that the GT 500 Shelby continues to be the king of muscle cars from 2007 till now. <span style="color: #000099">(The Corvette does not count as a muscle car as it is a Sports Car)</span> I am so glad i chose to buy a new 2007 Shelby when i did,
The Challenger is a good looking car but falls short in Horsepower and The Camaro just does nothing for me in looks! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] So i still like the Shelby GT 500 the best.
Old 11-21-2011, 03:09 AM
Big Block Bill Big Block Bill is online now
As we said in high school: &quot;But It's Still A Ford&quot; and history has proven: &quot;Sometime in your ownership you WILL have the heads off it&quot; .... 2013 ZL-1 Camaro is the way to go! No disrespect intended, really.
Bill
Old 11-21-2011, 03:23 PM
1970Bluel78 1970Bluel78 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Big Block Bill</div><div class="ubbcode-body">As we said in high school: &quot;But It's Still A Ford&quot; and history has proven: &quot;Sometime in your ownership you WILL have the heads off it&quot; .... 2013 ZL-1 Camaro is the way to go! No disrespect intended, really.
Bill </div></div>
I bet High School was a long time ago. This car is amazing and the ZL1 is very impressive but, is still wrapped in that ugly skin. Mustang 1 ZL1 0
1970bluel78
Old 11-21-2011, 03:33 PM
resto4u resto4u is offline
why does svt make the shelby instead of the real man in vegas? My opinion is it is not a real shelby, kind of like the 69-70 shelby mustang.
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 11-21-2011, 03:40 PM
Yes, High School WAS a long time ago. I agree the Shelby is a beautiful car but being a Ford : &quot;Sometime in your ownership you WILL have the heads off it&quot; probably because the seats fell out of them or the head gaskets leak. I am sure there will be a long line of people willing to pay $5/10,000 over list for the first ones off the line. I admit the car is very cool looking.
Bill
