Old 09-20-2013, 09:41 PM
L78racer L78racer is offline
Default Re: 62 Corvette Pure Stock Build
yup that's the one.
Old 09-21-2013, 12:22 AM
Ryan1969Chevelle's Avatar
Great Camaro.
Goes like stink.
We're you running iron heads in 2011? Testing my car memory.
Ryan
Old 09-21-2013, 01:17 PM
thanks.
yes. i put them on for the 2012 season.
Old 09-21-2013, 03:17 PM
Nice.
I try to meet new psmcdr people every year, but get so wrapped up in watching racing and checking out cars I don't socialize enough.
Will look you up next race, any changes planned?
Ryan
Old 09-21-2013, 03:37 PM
ok sounds good. we're always trying new things.
Old 09-22-2013, 10:35 PM
napa68 napa68 is offline
I spent a little time on the 62 this weekend. I received the gasket set for the injection unit and started to reassemble.
Then quite frankly, I was not happy with the quality of the plating on a bunch of the small items. Sooooooo off they go to the plater that has been highly recommended. http://www.detailplating.com/index.htm
Did you know these cars have a factory traction bar????
Old 10-03-2013, 02:35 AM
I have a friend who was playing around with the engine analyzer. These are the power curves that he came up with utilizing SAE net (water pump, fan, and fan clutch) horsepower numbers......
1. Published flow rates for stock 461X heads
2. Stock Duntov camshaft
3. 10.5:1 compression ratio
The 3 different curves represent changes in the cam timing and lobe centers.
Now I need to plug in 12.5:1 and see what if there is any reasonable gains to be had. I dug out a center section for the rear end in order to build the 4.56 diff. More on that later.
Tim
Old 11-23-2013, 10:49 PM
RichSchmidt RichSchmidt is offline
Cam within 1% of stock? Is this lift only? Is it at the valve after lash? Any rules on duration,and at what measurements? GM measured their duration off the seat,and gave some whacky numbers,Some factory cams listing over 320 degrees duration. I would look into that.
Heads are the biggie. Are 3 angle valve jobs and back cuts allowed? Are they measuring port volumes(I am assuming measuring chambers). Here are some tricks. When having the valve job done,have the shop open up the already machined area around the intake valve with a larger diameter cutter,and then mill the head back to stock chamber volume. Have the machinist cut the throat out into the bowl with a larger cutter. These areas are already machined,and I would be interested in if there is a spec for them. If you can cut the throat,but they will measure the port volume,you can usually mill material off the intake face of the head and use thicker gaskets to bring the port volume back down. You can have all the trick work done before the valve job,and deck surfacing,and then have the head shot blasted before finishing. Some very slick stocker racers have been known to put their heads in an oven,and get them soft,then take a hard metal pin and roll it back and forth over the pushrod pinch area to move the wall out without grinding.
Of course blueprinting the block with a plate hone job is a good idea. Do they measure piston to head clearance or deck clearance? Can you zero deck the block and restore quench distance with a composition gasket,or do you need to keep the piston down in the hole and run a steel shim like stock? A composition gasket is a trick in itself since you can get one that matches the head,not the bore,and it will give you even a tiny bit more room before airflow meets the bore. I doubt they will allow you to notch the bores.
Is there an allowance for +/- on stroke and rod length. You can resize the rods a bunch to shorten them and then turn the crank down 20 or 30 under with enough offset to get some extra stroke without tipping your hand as far as machined pistons or whacky deck clearances.
How about a lower volume oil pump,and running less oil in the pan? Run a machined down pump (not a stock size pump with a weak spring) to reduce the amount of power needed to turn the pump,and to reduce the amount of oil flying around,and to reduce the amount of oil you need in the pan.
I would think they require stock thickness ring grooves and rings,but can you run a gapless ring,and low tension oil rings?
I figured I would throw these ideas out there.
Old 11-24-2013, 01:52 PM
best to start here.
http://www.purestockdrags.com/p/rules.html
then give them a call. they will gladly answer your questions.
Old 11-24-2013, 10:27 PM
I would also like to know what of these potential modifications are over the line?
Ryan
