Old 10-15-2013, 08:45 PM
Guest
Posts: n/a
Default 72 Chevelle vin locations
Where are the vin locations on a 72 Chevelle? Thanks in advance.
Old 10-15-2013, 09:06 PM
SS427's Avatar
SS427 SS427 is offline
Default Re: 72 Chevelle vin locations
On the dash VIN plate behind windshield, on firewall behind heater box, on the frame, on the blue VIN decal on the drivers door, stamped on the engine pad and lastly on the transmission housing.
Rick Nelson
Old 10-15-2013, 09:49 PM
Guest
Posts: n/a
Thanks for the reply. Can you be location specific for the frame vin location. If its not info intended for an open forum please PM me Thanks Frank
Old 10-16-2013, 01:19 PM
SS427's Avatar
Depends on the plant Frank. More often then not they are on the top of either frame rail aft of the rear axle hump. Some plants seldom stamped the frames (yes I know it was a federal mandate) so just because there is not one there does not necessarily mean it is incorrect. They were also stamped very shallow so any amount of surface rust or pitting can obscure it.
Rick Nelson
Old 10-17-2013, 04:01 AM
Guest
Posts: n/a
Thanks so much...I will hunt it down following your advice. Hopefully it pans out. Thanks again. Frank
