Old 05-18-2016, 04:41 PM
RS_COPO_Canuck RS_COPO_Canuck is offline
Default 70 Nova Bench Seat - Adjustment
Just got a 70 Nova.
The bench seat wont go back far enough.....my knees are almost hitting the steering wheel.
Before I remove it to look - are there multi mounting holes in the seat track so I can remount the seat to the track to position it farther back?
Thanks All
Old 05-18-2016, 06:17 PM
earntaz earntaz is offline
Default Re: 70 Nova Bench Seat - Adjustment
If it helps -- on my 71' there are only one set of bolt holes ... TAZ
Old 05-18-2016, 07:02 PM
jasonL78 jasonL78 is offline
Nope only 1 set of holes. You can make a plate for each mounting hole to extend the tracks back. But on a nova as you go back you go into the rear floor pan slope.
Looking for the next project.
Old 05-18-2016, 07:49 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jasonL78</div><div class="ubbcode-body">Nope only 1 set of holes. You can make a plate for each mounting hole to extend the tracks back. But on a nova as you go back you go into the rear floor pan slope.</div></div>
Also -- the seat belts attach points may become an issue ... TAZ
Old 05-19-2016, 12:26 PM
Thanks all.
Yes - I was looking at the outside seat belts....it would be close but I think they may clear.
A friend has the same space problem in his '70 Nova.
Weird - every other &quot;compact&quot; car I ever owned that had a bench always had plenty of room.....Dart's, Duster's etc.
I'm going to remove it and have a good look.....
Old 05-19-2016, 12:40 PM
YENKO DEUCE REGISTRY's Avatar
Nope, one set of holes and minimal adjustment - bucket seat mounting isn't much better (might even be worse!)
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 05-19-2016, 01:11 PM
Thanks - It just so happens to be a Deuce :^).
I guess I'll get a leg reduction
Old 05-19-2016, 01:12 PM
68l30's Avatar
68l30 68l30 is offline
If you're good at fabricating you many be able to relocate the seat mounting points by reworking the tracks. I modified my bucket seats to add two inches to the rear by taking it from the front of the tracks. Cut and weld. Floor mounting is the same, but your seat is further back and dropped down a bit lower for head room. Very hard to notice, but the extra room made a difference.
BIG
Old 05-19-2016, 02:10 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RS_COPO_Canuck</div><div class="ubbcode-body">Thanks - It just so happens to be a Deuce :^).
I guess I'll get a leg reduction </div></div>
Which one?
Marlin
Old 05-19-2016, 03:25 PM
DEUCE DEUCE is offline
You guys must be very tall, I am 6'4&quot;, and I fit in with out much problems.
Mike
