I have alot of miscellaneous parts comming up for sale and will be posting them here.
First up: P stamped u-nuts for head light bezels, grill stiffer, grills and more 50 for the set of 6 shipped to the lower 48. ![]() ![]() |
Camaro Chevelle Firebird Nova GTO emergency brake cable equalizer p stamped. Excellent restored condition. 30 shipped to the lower 48. 3 available.
64-67 327 High performance L79 L76 L84 fuel pump to frame rubber line brass fitting w/weatherhead logo. SOLD 40 shipped to the lower 48. SOLD
Heater hose to alternator mounting clamp with small 3/8 hex indented head rbw head marking Bolt. Some cars throughout 69 used the smaller hole to mounts the clamp this is quarter 20 thread other cars used 5/16 thread. I've had several people ask me for these. Clamp and bolt $50. If you just want one of the 3/8 hex head rbw head marking bolts it's $25 shipped to the lower 48. I have 4 clamps available and about 10 bolts available.
Camaro Chevelle Firebird Nova Noise suppression capacitor. Repros that aren't even close sell for 52.00.
Excellent original condition with D headmarking mounting bolt. 85 shipped to the lower 48. ![]() ![]() ![]() |
Emergency brake cable connectors with double D stamping 2 pairs REALLY NICE RESTORED 60 per set shipped to the lower 48.
Power Steering hose clamps For Camaros Chevelles Novas and Impalas. This is also used on 68-72 Corvettes for the expansion tank hose. The original clamps are wittek #2 later replacements are wittek #23. 2 required per car. 60 per clamp shipped to the lower 48. I have 6 clamps available. ( 2 clamps sold 4 still available)
69-73 Z28 LT1 Engine bolt kit includes are:
12 [] exhaust manifold bolts 12 C intake manifold bolts 2 K stamped engine lift brackets 2 Flat head A engine lift bracket bolts Alternator mounting hardware Long RBW A thin head bolt WB upper bracket adjusting bolt+washers RSC lower bracket to water pump bolts 8 M Valve cover bolts 2 Anchor Fuel pump mounting plate bolts 2 (((E))) Fuel pump bolts CH distributor clamp bolt + clamp 3 NAT lower pulley bolts 1 CH balancer bolt + washers 2 J Coil bolts 4 AS Fan clutch to water pump hub bolts 11 L timing cover bolts 14 [] oil pan side rail bolts 4 J oil pan corner bolts 1 [] oil pan drain plug 4 ((EL) Inspection cover bolts 6 RBW Engine mount to block bolts 4 C Water pump to block bolts 4 tapered end carb studs RBW and stud thermostat housing bolts ALL ORIGINAL ASSEMBLY LINE CORRECT HARDWARE IN EXCELLENT CONDITION SYC PRICE 800 SHIPPED TO THE LOWER 48. |
