Old 01-28-2019, 04:54 PM
Enoch Enoch is offline
Banned
To sets of original tapered carb studs. $80 a set of four shift to the lower 48 PP FF
Both sets are sold thanks S Y C
Old 01-28-2019, 05:08 PM
Banned
Fender lip to wheel well mounting bolts. This is a unique bolt that they do not reproduce. The bolt is based off of the 396014 GM part number with the recessed hex flange head and pinch Point tip. But what's unique about this is it has a large flat captured washer. Rbw head marking. 30 available. $10 each. You won't find these reproduced anywhere. Free shipping on two or more bolts. Ppff
***********SOLD **************
Old 01-28-2019, 06:09 PM
Banned
69 to 74 small block balancer mounting bolt and balancer pulley mounting bolts. TR head marking. Excellent unrestored condition on all parts and pieces. $45 shipped to the lower 48 ppff
*************SOLD ***************
Old 01-28-2019, 06:11 PM
Banned
65 through 74 396 427 454 Big Block fuel pump pushrod plug. One with W head marking the other with L head marking. $40 each shipped to the lower 48. Ppff
**************SOLD ***************
Old 01-28-2019, 06:13 PM
Banned
Corvette Camaro Chevelle Nova smog pump mounting hardware. To RSC head marking bolts that mount the diverter valve to the pump and three are VW head marking bolts that mount the pulley to the pump. All excellent unrestored condition. $50 shipped to the lower 48. Ppff
Old 01-30-2019, 02:11 PM
Banned
Multiple headlight washer, vacuum line, air vacuum take off, PCV and washer check valve Tees.
First headlight washer T's. They do not reproduce this tea which allows the hoses to completely but adjacent to each other with just a thin plastic line between the two. $25 a pair
Second are the black and translucent vacuum line tees if you notice the different colors designate the inlet and outlet Port sizes. These are uniquely shaped and are for 68 and 69 Rally Sport Camaros. $25 each
Third headlight washer Barrel check valves. Black, these are the anti-siphon valves that keep the washer bottle from completely draining once the headlight washers were activated. They don't reproduce this. Very hard to find these two work perfectly. $50 each
Fourth is the Way I Are vacuum pull off T. Translucent raised pad with part number on it. Extremely hard to find in good condition. This is also correct for 1967 through 69 tripower vacuum secondary lines. SOLD $75 SOLD
V is 1970 on up black PCV hose tee. With original part number embossed on it and the original hose and two perfect original olive green clamps with <u> stamping. $60.
**************SOLD ****************
Old 02-01-2019, 04:25 PM
Banned
Four original Murray Corporation gold seal air conditioning hose clamps. Excellent original pieces they don't Repro these with the original manufacturer stampings on them. $25 each shipped to the lower 48 ppff
Old 02-01-2019, 04:33 PM
Banned
Radio delete coil bracket and bolts, perfect untouched Survivor condition. What makes this show it came from a radio delete car is that the screw hole for the capacitor on the back never had threads. Very hard to find. $50 shipped to the lower 48 ppff
Old 02-01-2019, 05:53 PM
Banned
Camaro Nova 12-bolt multi Leaf rear spring t-bolts. M head marking. 2 as nice as you will find. SOLD $60 shipped to the lower 48. Ppff. they still have the Machining marks on the surface. Nicest ones I've seen SOLD
Old 02-01-2019, 07:20 PM
Hrlyfxdl's Avatar
Hrlyfxdl Hrlyfxdl is offline
Hi Rich, I'll text you. Interested in an order. Shane
The Following User Says Thank You to Hrlyfxdl For This Useful Post:
Enoch (02-01-2019)
