#11
It has repo rear axle housing weld on spring perches too!
#12
Wrong brake pedal pad, rockers should be painted black for starters. A lot of money with things wrong...
#13
69z
Lots wrong with this one . The rear u bolts are handsome
#14
the heater hose nipple on the water pump ... NICE
Barry Allan |
#15
Plus the water pump is ribbed for your pleasure. ROTFLMAO |
#16
Mike!!! are you getting frisky
#17
Sorry I couldn’t help it, just trying to lighten up with everything going on in the world.
Seriously, you would think a car advertised for $182 K US Dollars would not be able to be picked apart. FWIW, I don’t like the tag . |
#18
I read more of the ad and the explanation of low miles. Doesn't appear from the ad that any of the power train is original. Poorly executed "restoration" of a put together car using an old drag car shell.
#19
the vinyl top molding placement looks wrong, too wide of a gap on the sides
1969 Camaro SS 396/375 4 speed fathom green, dark green vinyl top, medium green standard interior 1970 Corvette convertible 350/350 4 speed cortez silver |
#20
Nice passenger side valve cover breather hose, and the "brand new" spare wheel!
