Old 06-18-2021, 05:37 AM
1crossram 1crossram is offline
Default 1967 camaro parts wanted
Looking for a small collection of items
3909909 pipe support assembly for power brake P.242 in AIM
3859326 water pump dated prior to November 1966 any condition
3909817 alternator pulley for 1100750 alternator
1100750 alternator dated prior to November 1966 any condition
2 screws 5/16" NC X 1" to mount console to floor (large philips head)
2 screws that hold the rear console light to the housing
clip that holds the clutch/brake pedal in place (under dash at end of shaft)
67 Black convertible sun visors
coil bracket for a 350 (Seems the coil bracket I have is on an angle and I was told it was for a 69 with the cowl hood. Angled bracket id also correct for 67 327 or 350, with the large air cleaner, so I found I have the right one). FOUND I HAD THE CORRECT ONE
coil for a 350
radio side mounting bracket
the small clips that accept 5/16" bolts to attach the inner fenders to the fender in the engine compartment
passenger seat cable that prevents the seat from going to far forward FOUND THANKS MEMBERS
Thanks everyone
1967 Camaro RS/SS convertible Butternut yellow with black power top, factory AC
Rebuilding 1967 RS headlight motors
Tags
1100750, 3859326, 3909909, coil, coil bracket
