I moved this so the 68 Gibb COPO Nova has a thread dedicated to all things related to these unique and rare 68 COPO Nova. I want to thank Ray Morrison for his research and dedication to these cars and sharing his information these cars and being a great caretaker and historian.
I am the original owner of #37 of the Gibb COPO Nova's which originally was prepared by Dick Harrell. I had no idea my car was anything more than a Dick Harrell prepared 427-450 68 Nova with an experimental automatic? The article I read in the November 1968 issue was about the hot new 396-427 Nova available through authorized Chevrolet dealers. This article is the reason I came to ownership of one of these cars. This article did not disclose anything about Fred Gibb & his original purchase of the 50 copo's. Only in 1989, was I later to find out the rest of the history from Fred after I had a bug put into my ear that more background of this car might be worth checking? Should you Not have the engine code on the Gibb Novas or transmission codes, they are E3 that may be hard to find in any Chevrolet manual and the experimental 400 coded as CY. This special engine code I have wondered if that might have been arrived at because of the experimental 3 speed automatic? The E3 engine code brought up a lot of questions, but in talking with Fred before his passing, he told me all 50 COPO 9738 Nova's had that code. Ray Last edited by Steve Shauger; 12-27-2023 at 12:14 AM. Reason: Dedicated Thread on 68 COPO Nova |
The Following 13 Users Say Thank You to copo-2 For This Useful Post: | ||
1967Z28 (12-29-2023), Bill Pritchard (12-27-2023), Carleen (12-22-2023), carnut4life (12-22-2023), dykstra (12-22-2023), L78_Nova (12-22-2023), ls6owner (12-22-2023), lycan (12-23-2023), olredalert (12-22-2023), PeteLeathersac (12-23-2023), SS427 (12-22-2023), Tenney (12-29-2023), Xplantdad (12-21-2023) |
Looks like all were E3
William,
Your posting of the 1968 Chevrolet new vehicle inspection & adjustment schedule form is quite interesting. I first noticed just a couple differences in that of the #37 car. Build dates & a miner difference of having a 3 in the transmission code? By chance, You wouldn't have a shot of the green tag from this car? From the VIN number of posted schedule, according to my documents this would be from #49 of the 50? Helen Gibb wound up with the #50 car located in Gladstone, MO. The last 20 of this lot were paint coded EE being Fathom Blue. The engine code on #37 shows TO621E3.The transmission code on this car, however shows 68C100? The rear axle code shows BV0619G. The difference in the transmission code having the 68C103 I don't understand the being a difference? Long ago, research was done the found novas with this documentation, & the findings were that this 68C100 was the first part of the transmission serial number? I don't remember specially since a lot of the information on others was misplaced, car #37 had the lowest serial number of CY 1005 while the highest found was CY 1041. This seems to say that these Gibb cars transmissions had serial numbers ranging from CY 1001 To Cy 1050? William, this is just my theory, but have no proof? We know for sure, they were the first aromatics to be harnessed to a high performance, solid lifter engines in the first 2 weeks of July 1968. Documents from NHRA files, showing all 50 were built and delivered to Gibb Chevrolet by July 15. William, I realize this thread was started mostly about the ZL-1's and not trying to high jack that information, but there is quite a bit of information about the COPO Nova's that need addressing for public interests that we can discuss about these once called "Mystery Nova's? Ray |
The Following 8 Users Say Thank You to copo-2 For This Useful Post: | ||
69M22Z (12-23-2023), carnut4life (12-23-2023), dykstra (12-27-2023), olredalert (12-23-2023), PeteLeathersac (12-23-2023), SS427 (12-22-2023), tunes (01-06-2024), Xplantdad (12-22-2023) |
What I think happened is the transmission plant initially muffed the date coding.
TH400 transmissions were date coded with the model year [68], application [C]. Numbering began at the chronological day of the calendar year [1/1/1967] the MY launch occurred. The numbering continued to increment as the MY crossed into the next calendar year; did not reset. An early production TH400 trans for a 1968 Camaro would be 68C220, built August 8, 1967. A late production trans would be 68C543, built June 26, 1968. The 396/TH400 Nova was a Spring 1968 launch. When the plant started building the new Nova TH400 transmissions, they incorrectly started the date code sequence as of January 1, 1968, not 1967. Common dates for the Gibb L78 Novas are 68C100 [April 9, 1968] 68C101, 68C102, 68C103, 68C104. Someone noticed and later cars had transmissions coded 68C534 [June 17, 1968]. Common dates for TH400 ZL-1 Camaros are 69X361, 69X362, 69X395, 69X407. Don’t know about 1968 but for ’69, each transmission had a serial number with the sequence specific to the application, starting at 1000. Latest ’69 CX TH400 is CX-69-4285. A CC trans built at the same time is CC-69-25788. Just for the record, based on POP data our db shows one L78 and one L72 Camaro built with CC transmissions. Some very early 69 L78s built at Van Nuys had CY transmissions. I do have ZL-1s on the brain but it’s a Gibb Chevrolet thread. The L78/auto Novas are an important part of the story. Post whatever you wish!
The Following 12 Users Say Thank You to William For This Useful Post: | ||
1967Z28 (12-29-2023), 69M22Z (12-23-2023), bcmiller (07-26-2024), carnut4life (12-23-2023), dykstra (12-27-2023), lycan (12-23-2023), olredalert (12-23-2023), PeteLeathersac (12-23-2023), RPOLS3 (12-25-2023), Steve Shauger (12-23-2023), Tenney (12-29-2023), Xplantdad (12-23-2023) |
Thanks for posting the information on the vehicle inspection sheets. It seems to get more interesting to compare the information that each contain? These posted sheets are a little different from that of mine and if you look at the one you posted on the #49 car, it too is a little different? I believe the 3 last posted are from cars #20, #22, & #24 if my records are correct? Back to the #49 Fathom Blue, the document showed C103 at the bottom. Now the next to last of these cars would have been built the 2nd week of July 1968? #37 was also built the 2nd week of July 1968? In the latest post of the documents, they were from a tripoli turquoise car #20, & 2 matador red cars #22 ? These would have been built the 1st week of July 1968? Notice that at the bottom of the inspection sheets of the first week cars and the 2nd week car? The #37 car has a 534 Julian date code on the Green Tag in pretty large numbers up by the rivet, yet has no reference of the 534 found on the inspection sheet? When I first saw the C103 on the blue car, after thinking on this awhile was wondering if it would be possible that the 103 could be lacking another digit as 103? for the serial number? Maybe this could be the reason they were known as Mystery Novas?
William, thanks for passing on the information you have on the Gibb cars & their history. I'm sure there is a lot yet to be learned about these Gibb cars, but comparing information is the one way to learn more? Too, I presume you have secured the documents prepared by Fred Gibb titled "To Whom It May Concern" on the Nova's? Just wondering if those owning the ZL-1's may have been presented with these, also? |
Thanks for the reply about the individual Nova & ZL-1 documents. Your response kinda clears up something I was wondering about? I do have one that goes into detail about the #37 Nova down to the key numbers. Other things within this document addresses the 90 day warranty, the benchmark about being the first to inherit an automatic mated to a high horsepower, high rpm solid lifter engine, among other things & signed by Fred.
Back to the inspection schedule sheets, the differences I noticed at the bottom, just thinking these inspections may have been done by different individuals? The one I have was signed by Doyle Alston? If different people were responsible, could this affect what the difference might have on the way they were made up? If you don't care, take a look sometime at who signed off on these to see if they had the same signature? Ray |
Don't have them. Just got pics of the POP data.
William,
I would like to apologize for the lack of understanding pictures you posted were of the POP’s and not the inspection sheets of those. I will attempt to send my copy to this thread? I have been trying to upload some material of mine that came with the car as new. Not computer knowledgeable, but hopefully this will attach? Last edited by copo-2; 12-26-2023 at 04:19 PM. |
The Following 12 Users Say Thank You to copo-2 For This Useful Post: | ||
169indy (12-27-2023), 1967Z28 (12-29-2023), 69M22Z (12-27-2023), Andy (06-24-2024), Big Block Bill (12-27-2023), Carleen (12-27-2023), dykstra (12-27-2023), Eck (12-26-2023), olredalert (12-26-2023), PeteLeathersac (12-27-2023), RPOLS3 (12-27-2023), Steve Shauger (12-26-2023) |
Would Like to mention, the GM warranty on these Nova's was for only 90 days.The POP was used one time for a voltage regulator.
The Following 4 Users Say Thank You to copo-2 For This Useful Post: | ||
dykstra (12-27-2023), olredalert (12-27-2023), PeteLeathersac (12-27-2023), Steve Shauger (12-27-2023) |
William has been providing a lot of interesting documents concerning the 9738 COPO Fred Gibb had GM build revised version of the Turbo 400. 50 of these were built coupled to the newly introduced 396-375 SS Nova. Documents from NHRA files show that 50 RPO L-78 Novas being sent from the Chevrolet Motor Division and signed by Paul Pryor notifying them that 50 of such Novas were built in a letter dated April 24, 1968. Another letter sent to NHRA states that 73 RPO L-78-375 RPO Novas were built and available by May 1. But it wasn’t until July 24, NHRA was notified that the 50 automatic Fred Gibb Novas were built and delivered to the Gibb Cheverolet dealership on July 15. Most know NHRA required 50 factory built units with the same identity to be available before they would set up a new competition class.
These documents I have were brought about by discussion about the E3 engine code. This has been a point of interest since early on when these cars were uncovered as something that was mainly hidden away without owners of the few in existence knowing the story behind them? The Fred Gibb dealership had advertised them in Drag World as "There're Here, Be one of the Few 50 396-375 Nova Automatics." Some realized the difference and bought them as such, yet didn't realize and know the story of what they really were? Last edited by copo-2; 12-27-2023 at 07:56 PM. |
The Following 3 Users Say Thank You to copo-2 For This Useful Post: | ||
