Go Back   The Supercar Registry > Supercar Registry > Supercar Registry
Old 12-03-2024, 12:47 AM
Chazbo Chazbo is offline
Default Pictures of vin
Here are pictures
Old 12-03-2024, 02:23 AM
Jonesy's Avatar
Jonesy Jonesy is offline
which website did you run the VIN on that said it was a COPO? I know of one site that is falsely identifying pretty much any Camaro VIN inquiry as a possible Copo. Cant think of it of the top of my head right now
Old 12-03-2024, 01:19 PM
Old 12-03-2024, 01:40 PM
I see a small block heater box and no hole that I can see where the cowl induction solenoid would attach to the firewall.
The Following 2 Users Say Thank You to Charley Lillard For This Useful Post:
big gear head (12-04-2024), mhm1966 (12-11-2024)
  #15
Old 12-04-2024, 12:42 AM
Rick H Rick H is offline
Yenko Premier Member
Pictures are very dark. Take a picture of the firewall behind the brake booster.
Thanks
Rick H.
Old 12-04-2024, 10:26 PM
Default Pictures
Let me know if you need to see something else
Old 12-04-2024, 10:48 PM
R68GTO R68GTO is offline
Doesn't look like it has the ZL2 hole above the bulkhead. Aside from COPO question, you might want to check the hidden VIN under the wiper panel (top of cowl on passenger side) to see if it matches the VIN plate. It appears that the top of the dash panel was replaced, which is usually due to past rust issues, yet you have a perfectly crisp VIN plate which might suggest something was changed/replaced there.
Chazbo (12-04-2024)
  #18
Old 12-07-2024, 05:27 PM
Kurt S Kurt S is offline
It was not a COPO.
I agree with Jonesy - every VIN you enter into that site says it's a COPO....
Kurt S - CRG
The Following User Says Thank You to Kurt S For This Useful Post:
  #19
Old 12-07-2024, 05:43 PM
Sean Sean is offline
That is not even close to a COPO. Wishful thinking sorry to be blunt.
70 LS 6 4 SPEED CHEVELLE
69 SS 396/375 HP 4 SPEED CHEVELLE
68 SS 396 CHEVELLE SS 396/375 4 SPEED
69 COPO CHEVELLE 4 SPEED #S MATCH
69 COPO CAMARO #S MATCH SURVIVOR (BLACK)
69 COPO CAMARO (BLACK)
55 GASSER L88 4 SPEED
66 NOVA "UNDER CONSTRUCTION"
70 440 SIX PAK CHALLENGER SUPER STOCKER
2001 RVW/LDR TRANS AM 1020" BBC 8 SYSTEMS
Old 12-07-2024, 09:18 PM
Jonesy's Avatar
I just entered my 69 Camaro RS/Ss 350 VIN in and it came back It’s a possible COPO ZL1. So I guess I got an Azure Turquoise RS ZL1. That’s gotta be a 1 of 1
