#131
![]() ![]() ![]() Super nice original chrome finish air cleaner wing nut. Open flat design. won't find a nicer original chrome on one out there. Great for a survivor or restored car. Two very small wear marks on the bottom side where the nut contacts the air cleaner. SOLD $100 shipped to the lower 48 SOLD this is the nicest original 1 I've had in a long time |
#132
![]() ![]() ![]() 69 Camaro, Firebird dual exhaust rear muffler hanger to frame rail mounting bolts. Excellent unrestored original condition retains all their original plating. TF head marking. Not being reproduced this head marking. 100% real. $60 per set (4 bolts per set) shipped to the lower 48. Two sets available. |
#133
![]() ![]() ![]() 68 - 69 Corvette tri-power air cleaner base to carburetor mounting bolts. LF head marking very nice original condition. $100 shipped to the lower 48. |
#134
![]() ![]() ![]() Corvette Camaro Chevelle Nova Impala GTO 442 speedometer gear retainer mounting bolt, flathead U head marking with captured lock washer. Very nice original. $25 shipped to the lower 48 3 available |
#135
![]() ![]() 70 - 72 TCS vacuum 4 way T. This is an excellent original condition original aged yellowed look not white like the NOS ones. $30 shipped to the lower 48 |
#136
![]() ![]() 69 Camaro Corvette Impala headlight washer anti drip siphon valve. Correct black color tested works perfectly. $75 shipped to the lower 48 |
#137
![]() ![]() ![]() Camaro Chevelle Nova Firebird GTO Impala 442 gas tank sending unit ground wire mounting bolt. They do not reproduce this bolt in any way shape or form. Unique to this application. Quarter inch recessed hex head RBW head marking flanged head captured star washer blunt tip. $50 shipped to the lower 48 perfect original plating. These are usually rusted stripped busted missing. 4 available. |
#138
![]() ![]() ![]() Original survivor big block chrome valve cover retainers. The reproductions aren't shaped correctly. These are an original set of factory chrome retainers. $200 shipped to the lower 48 |
#139
![]() ![]() ![]() 1970 through 1973 Corvette door ajar switches. These are very hard to find in working condition. These are in excellent condition the pin the sleeve in the spring move and slide freely, these are usually all bound up or bent or busted. Excellent original survivor plating. 120 shipped to the lower 48 |
#140
![]() ![]() ![]() ![]() 67 68 69 Corvette Tri Power Air Cleaner Lid ORIGINAL. It has been rechromed once and they taped over the silk screening so it will need to be stripped and rechromed. 300.00 shipped to the lower 48 |
