Old 06-27-2016, 12:14 AM
Ryan1969Chevelle's Avatar
Default Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
Oh I mixed the O and the I:-(
Bet that has never happened before:-)
Ryan
Old 06-27-2016, 12:19 AM
All good Ryan....,It was a great fun day at the track
[img]<<GRAEMLIN_URL>>/[/img]
Old 06-27-2016, 07:59 PM
junior supercar junior supercar is offline
Good to see you this past weekend Ryan. And good to finally meet Dan.
those bolts look familiar :-)
I thought you said the driver exhaust mainfold had the heat riser valve. do I need to check my eyes (it's possible)
Tom's 69 special is a STUNNING car. 14K mile car. I'll have my work cut out for me on my W-31, which is currently undergoing a frame off and WILL be raced the the Pure Stock Drags.
1969 Cutlass S W-31 - 13.86@100 TnT US41 2009
1970 Tempest GT-37 400ci 4bbl 4sp - [email protected] PSMCDR 2011
1970 F-85 - daily driver or clock it with a sun dial
plus others
Old 06-27-2016, 08:04 PM
looks like your distr may have a green(? or blue?) stripe above the casting number.
those original plug wires are probably junk. Fusick (among many other places) should have 1-Q-69 dated reproductions for you.
plus others
Old 06-27-2016, 08:22 PM
Chris,
Great meeting you too [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Will your W-31 be ready for this years Pure Stock Drags or in 2017?
What color is your W-31? You and Ryan will be a good side by side race....I have my money on the experience, sorry Ryan [img]<<GRAEMLIN_URL>>/burnout.gif[/img]
Old 06-27-2016, 09:28 PM
Great to see you too Chris.
Thanks for the bumper bolts, one more item off my &quot;spread sheet of fun&quot;
These manifolds came for California via Chicago, but no heat riser, I disn't ask for it and as far as I know wouldn't use one....... Aren't they for winter start ups?
I will check for markings on my pictures of the distributor.
Do you know how the date codes work? When were my originals made?
Ryan
PS: Chris' W31 is (correct me if I am wrong) North Carolina tar heals blue) Olds translation to follow:-)
Experience.......... Got to get me sum-dat!!!!!!
Old 06-27-2016, 10:27 PM
Glade Green vs. North Carolina Blue this will be a nice photo at the starting line. I see Ryan, improving his times upon every run....and almost catching Chris. It will be a fun day [img]<<GRAEMLIN_URL>>/[/img]
Old 06-27-2016, 10:48 PM
earntaz earntaz is offline
Ryan -- the heat riser when partially closed will force exhaust gases through the intake manifold (usually under the carb) to provide heat for cold/damp conditions. That will prevent icing of the throttle blades, etc. Down here in south Texas there is probably no need for that mechanism. But in the northern tier states including Canada I would run the heat riser. That will cutdown on how long you may need to warm up the engine before driving. TAZ
Old 06-27-2016, 10:50 PM
A Carolina Blue '69 W-31 may very well be a 1 of 1....as I have never seen another [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 06-27-2016, 11:20 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Ryan -- the heat riser when partially closed will force exhaust gases through the intake manifold (usually under the carb) to provide heat for cold/damp conditions. That will prevent icing of the throttle blades, etc. Down here in south Texas there is probably no need for that mechanism. But in the northern tier states including Canada I would run the heat riser. That will cutdown on how long you may need to warm up the engine before driving. TAZ </div></div>
That is what I thought it did, helpful even on cold mornings? Lots of people throw them away?
Aren't they a significant resistance to exhaust flow?
Ryan
