Old 01-09-2009, 11:28 PM
Jacsey 70Z Jacsey 70Z is offline
Default Re: Correct coil for '70 LT1?
Looks like it says 12V instead of B-R wonder what the difference is if any or is it just a change made in the later ones.
Jack Seymour
1970 Z28
Hugger Orange
20K Mile Survivor
Old 01-10-2009, 01:00 AM
I believe the numbers on the coil only really designate the type (offset)the bracket has.
Old 01-10-2009, 11:15 PM
Those really stood for the last 3 digits of the part.i.e. Coil #1115293.
I've seen em embossed 12V,some 12-V,some BR and some B-R.
Why I don't know,but all have been found to have been used on the line as original equipment.
Old 01-11-2009, 08:00 AM
Just in passing. LT/1's in deuces, although they're stamped as a Z28 motor, use a 293.
Old 01-29-2009, 09:06 PM
YENKO DEUCE REGISTRY's Avatar
Schoneye is correct, the LT1's in Deuces were all 293's.
Marlin
Old 01-29-2009, 10:52 PM
Any thots Marlin on why 293s for the LT1s in Deuces and 270s for LT1s in Zs and vettes?
Old 01-29-2009, 11:20 PM
Sam, those numbers are for the use of the assembly line workers to put the correct coil bracket on the correct car for hood clearance and air cleaner clearance etc I believe. I think there were maybe 3 different types of bracket angles. The 69 Z/28's took a 298 coil. Same as the 293 but that number determined the bracket offset. The guys at the CRG Site or maybe Jerry MacNeish or Brian Henderson can explain it better.
Old 01-29-2009, 11:22 PM
So Sam, you're saying that maybe the Deuces had different (more) hood clearance than the vettes and Zs and the 293 or 270 would dictate the bracket angle thereby providing appropriate clearance?
Old 01-30-2009, 12:03 AM
Believe me Sam, I am NO expert but I think that would be correct. The coils 293 and 298 I believe have the same ratings. I am not sure if the 270 coil is a hair shorter than the others or not. My 69 SS nova has the 293 coil on it. My Z has the 298 coil with the flat hood.
Old 01-30-2009, 04:40 AM
I don't think that's right.
Embossed ignition coil numbers were not calling out the bracket offset for the vehicle they were going into,but rather an abbreviation for the last 3 digits of the actual Delco full seven digit part #.
In general,what set coils apart was the difference in the resistance wire they were wrapped with internally.
#202 coils measured 1.8 OHMs,#238 coils measured 1.3 OHMs,etc.
Chevrolet did use different coil mounting brackets w/varying angles,so using the examples above:
A 1969 Nova SS used a #1970344 coil mounting bracket.
A 1969 Camaro Z/28 w/flat hood used a #1971011 bracket.
A 1969 Camaro Z/28 w/Cowl Ind. hood used a #1966876 bracket.
I've yet to see a coil body reflecting anything close to the above bracket numbers,but would like to hear from anyone who has.
Why the application difference between a #270 vs. #293 vs. #298 on essentially the same engine may have had something to do with static interference,(mast antenna vs. one imbedded in the windshield which began in 1970),or even an overheat issue in a specific vehicles engine bay,or something as miniscule as using up old inventory for a newly designed coil.
I'm trying to learn too..
