Old 12-13-2009, 09:05 PM
firez firez is offline
Default Re: 302 pistons
I received an email from Jerry MacNiesh and he uses JE pistons. I will call them tomorrow and see what they have
1968 LOS Rallye Green Z28
Old 12-14-2009, 03:29 AM
X66 714's Avatar
X66 714 X66 714 is online now
When I built my 302, years ago, TRW was all that was out there. I had .200 taken of the domes to make them 11 to 1. I also had the ring lands opened for stock rings. Wasn't building a race motor. Was looking for long life....Joe
Old 12-14-2009, 05:29 AM
Yes I am looking for some reliability out of this motor.It might see 5000 RPM but thats about all.
Old 12-14-2009, 07:18 PM
X66 714's Avatar
I've barried the tach on mine after balancing. With 4.56 gears, it doesn't take long to get there.....Joe
Old 12-14-2009, 08:49 PM
The car has the CE engine in it now and with 3:73 gears it may have seen 6000 rpm. I am not sure if the CE motors were balanced from GM or not.
Old 12-14-2009, 09:19 PM
Crate motors and original motors were all the same back then I believe. Don't know if any were really "balanced" like a machine shop would do. When we bought crate motors we took them apart to check clearances more than anything back in those days.
Old 12-14-2009, 10:33 PM
SSRSBOB SSRSBOB is offline
Made a couple of calls. The J&E are the way to go. Exactly like the original GM and approved by NHRA for Stock Eliminator. No machining, no nothing, balance and install and you have exactly what the engine should have.
Bob
