Call Crash.
Don't mistake education for intelligence. I worked with educated people. I socialize with intelligent people. |
Call Crash. ![]() [/ QUOTE ] end of thread! Eric Davidson is the man for the Muncie!
Follow me on Instagram: https://www.instagram.com/mbcgarage/ |
What state is this company located in???
Thanks Peter |
I'm gonna be looking for a new trans for the Nova.The old one is toast,broken ear on the case,used up gears and syncros.More to rebuild it right than to buy new with the good stuff in it.The trans that was in it I beleave is a M20 with 2 rings on the input.Wouldn't mind a M22 with a supercase.That would do everything that I could throw at it. Any advise is appreciated. Thanks in advance. Kendall ![]() [/ QUOTE ]I haven't read all the responses, so it may be already said. But, it depends on how much power, how hard and often you use that power, how sticky R the rear tires and what rear gears are in it. All this comes to play in how long the weaker M-20/21 will last. I like the wide, M-20 (lower gears) for most stuff around town that has less than 3.73 rear gear.
If you don't drive it, don't talk to me. |
Ok so wide or close ratio?The Nova is street driven,375hp,headers,3.55 gears.The trans isn't numbers matching to the car so it's not that big of a deal about saving the old one.Just some spirited driving as every now and then I like to clean out the pipes if you know what I mean.
Kendall
70 Nova SS ZZ427 TKO600 5speed 3.55Posi |
My take would be a wide ratio. If it was mine I'd be taking a long hard look at the iron case, nickel gear Super T-10's built by SK Speed (NY).
Wayne |
With your 3.55 rear gears, it's an absolute no-brainer to go with the 2.5 Wide Ratio Muncie. It'll make leaving stop signs quite a bit more fun. It's also supposed to be worth an extra 2-Tenths on the Drag Strip if that's your thing which roughly translates into 2 car lengths. And c'mon now........we've all won or lost a street race by two car lengths before!
1962 Biscayne O-21669 MKIV/M-22 1962 Bel Air Sport Coupe 409/1,000 |
