![](https://www.yenko.net/forum/cache.php?img=http%3A%2F%2Fi852.photobucket.com%2Falbums%2Fab89%2F4onthefloor%2Fimg094.jpg)
Heres what kind of build im copying-It gonna be more like the 2nd graph but with 3rd graph type power-Im using my "290" Large Oval port heads that are closed chamber style-these heads have BIG valves in them-plus they been Worked on-so I will have more compression than they did on Sheet,The Cam is gonna Be a Comp Cams 294 XE series flat tappet-Comp Cams roller rockers-TrickFlow pushrods-Older Holley Street Dominator Intake manifold-My build differs-As Lingenfelter used a CompCams 252 H-Then a 305H-followed by a 288 Street Roller & a 296 Street Roller-The CompCams 294 Xtreme Energy Cam is a NEWER design with 250/256
[email protected] 588/593 Lift 110' lobe-2800-7000 RPM powerband-Lingenfelter also used a Holley Strip Dominator Intake manifold-then a Weiand Team G-I just so happen to have a "TeamG" intake laying around Just in case I have to push the power band up-My builder has done MANY 496 Builds-From what I was told it Should Be a HAND FULL with that M22 4 speed Im running-He warned me -that the Rear end in my Firebird WILL not LAST LONG with all the power going thru it-so In the future I will be upgrading to a Ford 9 incher-maybe a 12BOLT if I can score one for Cheap...
