Old 03-20-2013, 09:30 PM
1968BM 1968BM is offline
Send a message via Yahoo to 1968BM
Default Re: piston dome size need help
Now this is sounding more like what i need to know. Right now i have a 454 stndard bore with a forged crank and flat top pistons, and 049 heads. I have to get cylinder 4 sleeved and put back to standard bore. I dont think i can get enough compression out of the flat tops to be where i wanna be without out nitrous or supercharging. That is why i want to go with a forged dome piston. Now my question is this what sized dome can i put under the 049 heads? My other option would be to build a 427 out of it.
1968 Chevelle
427 BBC
Muncie 4 speed
Rats Rule
Old 03-20-2013, 04:45 PM
VintageMusclecar's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Stefano</div><div class="ubbcode-body">You are going about your quest Bass Ackwards.
You need to first determine what you expect to get out of your engine, which is based on many factors such as how you plan to use it and get out of it? RPM range? HP and TQ level? etc?
The only working parameter which you provided is &quot;pump gas&quot;.
Once you have determined the above you can decide on a combination that will best achieve your objective. </div></div>
This.
Old 03-20-2013, 09:35 PM
69 Post Sedan's Avatar
If you build a 427, you HAVE to use 427 pistons as the location of the wrist pin is different than a 454 piston......along with using a 3.76 crank vs. a 4.00.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-20-2013, 09:39 PM
Thanks, yes i knew that for the 427, ran into a guy that has all that, hes lookin to sell me for around 600 cash, just not sure yet which way i want to go.
1968 Chevelle
427 BBC
Muncie 4 speed
Rats Rule
Old 03-20-2013, 10:06 PM
ssl78 ssl78 is offline
I would check into building a 496 stroker motor, sometimes its cheaper to go that way the kits are fairly reasonable.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
