Old 06-11-2015, 06:55 PM
Thomas Thomas is offline
Default Re: 1969 Camaro Tie Down
I knew someone here would have the answer.
I will check for the holes.
Thank you very much.
Thomas Schilf
'69 Camaro SS, L78, M22, 4.10 Posi
'69 Camaro E/SA
'00 Camaro SS Convertible
'04 Harley FXST
'80 Chevy Blazer (My first new vehicle)
Old 06-12-2015, 08:21 PM
watk69 watk69 is offline
After almost beating by beloved 69 to death bringing it back from Iowa having it hop around using axle straps at the rear, I only use tire baskets fastened down to E Track in the floor
Clif
________
'69 Dusk Blue Z/28
'15 Red Hot Z/28
Old 06-12-2015, 09:18 PM
Dicky's Avatar
Dicky Dicky is offline
Hey Clif, just a question about tire baskets,
how do they keep the sprung body from bouncing
any different than axle straps? Thanks DH
Dicky
Old 06-12-2015, 10:51 PM
PxTx's Avatar
PxTx PxTx is offline
I was thinking of this thread today while I was tying something down in ky truck. I'm sure this is a very nice car, but I think you are better served by bolting a proper bracker than trying to use a sheetmetal hole from the factroy. I'm sure they only had intentions for it to be used one or two times. Here is a bed rail hole on my truck. I have over 250k on it and it is well used. I still would rather weld up two bolt holes than reproduce the rolled opening on a frame rail hole.
Another idea would be to disconnect the shocks, maybe?
Paul III
Old 06-12-2015, 11:08 PM
Day2_69Z Day2_69Z is offline
Where's the rust and dents ?
Day Two Specialties /High Quality Muscle Car Parts.
Old 07-26-2015, 10:55 PM
The front ones are just behind the holes for the bumper brackets in the subframe.
I have a set of the tie down hooks/chains(GM, FORD, Chrysler) we picked up from an auto transporter back in the late 70's.
Old 07-27-2015, 04:17 AM
Guest
Posts: n/a
Why not just do a double wrap on the rear spring just behind the U bolts and if needed do the same on the front portion of the spring. Use a synthetic sling so as to not hurt any finished surfaces.
Old 07-27-2015, 07:16 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Dicky</div><div class="ubbcode-body">Hey Clif, just a question about tire baskets,
any different than axle straps? Thanks DH </div></div>
My main interest is getting the car as a whole to stay put and not jostle from side to side on a slick floor in my trailer (its a Featherlite with an alum floor&quot;. I don't care too much if the suspension gets exercised on an OEM setup. But your's is a race car and I imagine body bounce on those slicks would not be a good thing at all. So strapping holes on the frame might be the best solution. My car with this welded down L Track system from Mac's the car did not move even a fraction all the way to and from Frederick MD
Clif
________
'69 Dusk Blue Z/28
'15 Red Hot Z/28
Old 07-28-2015, 01:20 AM
68l30's Avatar
68l30 68l30 is offline
Cross the straps....it won't move.
BIG
Old 07-28-2015, 01:31 AM
hiperf406 hiperf406 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: watk69</div><div class="ubbcode-body">After almost beating by beloved 69 to death bringing it back from Iowa having it hop around using axle straps at the rear, I only use tire baskets fastened down to E Track in the floor </div></div>
I've been doing this for years &amp; found it to suit me the best. I have hauled our cars thousands of miles with no problems.
lorne
63 Vette Rdstr (sold )
68 Z28 (May /68 build)
70 LS6 Hdtp.M40.4.10/Dec/69 build
When the flag drops the bullsh1t stops.
