Old 08-31-2015, 10:00 PM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
Default Re: Original paint '62 409hp 409
verne, didn't the 409s have a firewall mounted ballast resistor also?
Old 09-01-2015, 01:46 AM
442w30 442w30 is offline
Are there signs that would distinguish a 409/380 from a 409/409? Or the tell-tale signs the same?
Old 09-01-2015, 03:25 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 442w30</div><div class="ubbcode-body">Are there signs that would distinguish a 409/380 from a 409/409? Or the tell-tale signs the same? </div></div>
The ONLY things that would be different between a 380hp and a 409hp would be the throttle rod from the arm, the hot air choke tube from the carb to the manifold and the fuel line from the pump to the carb. I actually am concerned about even posting this info.
Obviously, the intake, carb(s), linkage, return springs, air cleaner and valve cover decals are also different but those are no a brainer.
Verne
(this applies to '62 only)
Old 09-01-2015, 07:51 PM
I only ask because the claim was being made it was a 409/409, so I was curious why the claim wasn't that it simply was a 409 car in general. Thanks for your answer!
Old 09-02-2015, 03:59 PM
Regarding the throttle rod, I forgot to mention that a straight one is also used with the 380hp (1x4) version. I can't tell from the photo what the length is, but it could be a good clue that the car was a 380hp 409.
Verne [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
