![]() Quote:
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
John Brown (10-24-2023) |
----Name of the place is CCI Driveline. Ph#586-716-1160. I know a lot of serious drag racers use them. I'm not sure but think they can high speed balance. Give em a call.....Bill S
The Following 2 Users Say Thank You to olredalert For This Useful Post: | ||
L_e_e (10-31-2023), Too Many Projects (10-24-2023) |
I've used the same people as Freddie. Cannot go wrong
The Following User Says Thank You to napa68 For This Useful Post: | ||
My '67 I am running a 3.5" steel driveshaft.
VRN in Lake Bluff IL makes the DS's for Strange, you could always email them for a quote. |
Don’t forget that MW & Strange use different pressure angles on their splines so the differential (or spool) and axles must be both from the same manufacturer.
1962 Biscayne O-21669 MKIV/M-22 1962 Bel Air Sport Coupe 409/1,000 |
The Following User Says Thank You to markjohnson For This Useful Post: | ||
big gear head (12-20-2023) |
BTW, a Carbon Fiber driveshaft is expensive but is supposed to be worth a solid tenth. You may get to a point where the car is extremely close to breaking an ET barrier and wished you’d spent a little more money!
![]() Quote:
Breaking the tail housing off at SCR was the least expensive part to replace.
They are the strongest and have infinite shaft speed, but are not at all abrasion resistant and not recommended for street car applications for that reason.
You have to be sure that you have clearance for a larger diameter shaft. You don't want it rubbing on something like exhaust pipes or floor braces.
I doubt that you would need to go with c clip eliminators if you buy quality axles. C clip eliminators have their own set of problems when used on the street. For one thing they tend to leak oil on your brakes. Once you install c clip eliminators it's very hard to go back to original.
The nice thing about carbon is if you brake a U joint and the shaft hits the ground. It will not beat the bottom of the car up. I have a carbon shaft on a 4k lb car that makes 800 at the tires cutting a 1.39 60 with a carbon shaft.
