Old 07-17-2001, 02:29 AM
Chevy454 Chevy454 is offline
Default Re: 1969 Camaro double COPO (ebay)
If my memory serves me correct, "BV" is 4.10 posi for both Nova and Camaro? I was having trouble reading anything on that protect-o-plate. What else does it show?
Old 07-17-2001, 02:48 AM
Man, you guys got a better screen than me! Is it a X11 or a X44? Almost reads X11 on my screen!
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 07-17-2001, 03:20 AM
Dan 68 Chevy II Dan 68 Chevy II is offline
Marlin,
Your right about the original stamps on the axle tubes,my 68 Nova SS 396 has the original 12 bolt with BV for 410 gears,their not stamped as crisp,spaced further apart and E is not on the same line.BV 0715 G2 E E28 8 casting date 3894860NF Dan
Old 07-17-2001, 04:47 AM
BE would be 410 in a Camaro
Old 07-17-2001, 05:56 AM
YENKO DEUCE REGISTRY's Avatar
Are the COPO Camaro 'BE' rears stamped that neatly? I know the '70 COPO Novas certainly aren't.
M
Marlin
Old 07-17-2001, 02:01 PM
Jeff H Jeff H is offline
Can anybody read the engine code on the P-O-P? I didn't think the rear code looked like BE, but it's not a very clear picture.
Old 07-17-2001, 04:26 PM
Rat_Pack Rat_Pack is offline
I messed with the picture in Photoshop and found that the rear code is BE and the engine suffix is MN. If you look at the upper left of the POP you can see that it has the H for a Holley carb. The date code for the engine was blurry but it may possible be TO521MN and the rear code may read as BE0519G. The month of manufacture on the POP shows to be a 5 which is May. Why is the rear end stamped as a February build date? Whomever restamped the axle tube may have read the 5 as a 2 on the POP since it is read backwards. I know I have done this many times before when trying to read a POP. I could not make out the VIN no matter what I tried but my guess is 124379N645657 which would put the car into the month of May for production.
Why doesn't someone email the seller for the info off of the POP? Oh well........RatPack.......
Old 07-17-2001, 04:51 PM
One other thing, the car is an X11 body code on the trim tag also note it has the 1/4 panel louvers, drip rail moldings, taillight vertical chrome trim, and headlight bezel chrome trim: wheel opening moldings and the rocker moldings have been removed at some time. Another thing to note on the trim tag is the build date is 05E. So the rear is definitely a restamp or out of another car, my bet is a restamp. Neat car anyways....RatPack........
Old 07-18-2001, 05:44 AM
tom406 tom406 is online now
Charlie, isn't BE for a heavy duty positraction 4.10 rear and BV for a standard duty positraction 4.10 rear, even in Camaros? Bob F. up here has a '69 L78 car with a BV rearend in it. It seems to have a correct drivetrain with all the date codes falling into the right timeframes. (I spent an hour or two going over the car for an appraisal a couple of weeks before he bought it). I thought all COPO's were BE. If the pop says "BV", would that make this suspicious, or just another exception to the rule?
Oh, yeah, as for the above BE stamped rear, I'll go on record saying I've NEVER seen a rearend stamped that deep, that evenly spaced, or that easy to read.
Old 07-18-2001, 08:49 AM
Bob Jenkins Bob Jenkins is offline
here is an update from seller on add:
I have had many questions reguarding the Protect-O-Plate info. So here it is: Line 1: 12437N649657 Line 2: T0121MN BE0519G Line 3: P9D28 133
1969 Camaro SS 396/375 4 speed fathom green, dark green vinyl top, medium green standard interior
1970 Corvette convertible 350/350 4 speed cortez silver
