The 73 Chevelle wagon has COPO typed on the build sheet. So it appears that special paint has something to do with the COPO process. It is only for the paint not a hi po option. Same with the Yenko Chevelles with special paint. There are three COPO option codes on the build sheet listed below the RPO options. The 427 COPO code, the Yenko COPO code, and a special paint code all on the same line. At least in these two examples the paint appears to be included as a COPO option. Why else would it be right on the build sheet as a COPO option?
Joe,
I'm not following: > The 427 COPO code, the Yenko COPO code, and a special paint code all on the same line. At least in these two > examples the paint appears to be included as a COPO option. If there isn't a COPO code listed it isn't a COPO item. They put all comments in the same area of the sheets. It just happens to follow the other COPO's and require the approval of the same office. There's no engineering required for a different paint color, just authorization. As for the wagon, that was 73 and they may have used the term at that plant to indicate there was approval by the Central Office. Who knows? I don't put a lot of weight in that sheet.....
Kurt S - CRG |
