Old 08-08-2003, 08:10 PM
PxTx's Avatar
PxTx PxTx is offline
Default Re: WANTED: 67 Camaro M21 Tranny
I'm guessing there was too much play in the tail of the trans. Either the output shaft was fatigued or the bushing was worn too much? Anyone else have thoughts on this kind of Muncie failureÖ
Paul T
Paul III
Old 08-08-2003, 08:47 PM
T Billigen T Billigen is offline
Do you guys use a scatter shield when you run your cars at the reunion? Very dangerous to run a solid lifter chevy without one! [img]/ubbthreads/images/graemlins/scholar.gif[/img]
1968 COPO/YENKO 9737 Non-Converted
Old 08-08-2003, 09:19 PM
JoeC JoeC is offline
It appears that something caused the trans to lock solid then the momentum of the spinning wheels, rear end, drive shaft, and Dyno caused the output shaft to shear in half and shatter the bell and trans housing. It is difficult to say without a close look at all the parts.
Old 08-09-2003, 04:35 PM
Chevy454 Chevy454 is offline
I don't think NHRA requires a scattershield on stick cars until you run in the 11's. Also, you take a risk of this happening regardless if you're running at the track or, as the case may be, running on a dyno...this could have happened on a cruise just the same. I've tore up more stuff on the highway than on a track by far!
Old 08-08-2003, 11:58 PM
crash crash is offline
Denis, I've got a P7E05 main case without a VIN or I have four 010 cases without any VIN or build dates...Hope this helps...Crash
Old 08-09-2003, 12:35 AM
Denis Denis is offline
VERY INTERESTED in the P7E05/NOVIN main case! PM me w/ phone # pls.
Old 08-09-2003, 01:17 AM
Denis, E-mail me for phone # [email protected] Crash
Old 08-09-2003, 03:50 AM
hvychev hvychev is offline
Dennis was this the original trans?
Frank Magallon
Old 08-09-2003, 04:48 AM
Busted trans had 'correct' dates and castings but no VIN. Not original to the car.
