Old 06-11-2005, 09:46 PM
Casey Marks Casey Marks is offline
Default Re: Everything You Never Knew About WD-40.
.... and hopefully no poor bastard tries to use WD-40 on their BBQ grille without realizing that they will be witnessing a fireball emerging like the Hindenberg .....
Old 06-12-2005, 01:44 AM
Belair62 Belair62 is offline
Old 06-12-2005, 05:35 AM
tjs44 tjs44 is offline
big or little,thick or thin,WD will get it in!Actually I have used it for starting fluid with my dsl engines more than once.Tom
Old 06-12-2005, 06:49 AM
I am cleaning up an Old Sunoco 260 Gas Station Blender Pump assembled in 1963 and have found WD-40 is the ONLY thing that will remove the old build up of Oil,Fuel stains &amp; outside element build up from it's enamel exterior paint.
It also frees up all the old digit gears in the process,as well as remove the stains from the Glass &amp; Stainless.
And it won't destroy the enamel paint either.
I have gone through 4 tall cans of it so far &amp; hope to have completed pix soon this week.
Old 06-13-2005, 05:17 PM
moparts moparts is offline
If you guys get a chance try some Sea Foam DEEP CREEP....it took over the WD40 spot in my tool box.
20 foot 75 hp good time at the lake
Old 06-20-2005, 08:01 AM
djunod djunod is offline
Wow, looks pretty good, let us know how you make out..
Stay away from the Gibbs... it's just a bunch of hype. I have something that I coated with it, that still ends up getting rust showing up in just a few hours (inside).
David
