Old 11-12-2005, 05:59 AM
gtaa9 gtaa9 is offline
Default Re: running rough
Before I bought the car all that was done(points,condensor,plugs,cap,rotor).I pulled the vacuum advance hose off and its getting full vacuum to the dist at an idle?I know that its not suppost to have full vacuum at idle only under full throttle.The vacuum hose gos from the dist to the back of the carb on the bottom.The only other place for a vacuum hose to hook up too is on the left front of the carb.I'm standing in front of the car as I'm looking at the motor.Any suggestions?
Old 11-12-2005, 06:12 AM
Seattle Sam Seattle Sam is offline
You should be hooked up on the ported vacuum (left front of the carb), you don't need all that advance at idle. Be sure to cap off the port you are coming off of. Set your initial timing with the vacuum line off the carb and the vacuum ports on the carb all blocked off. You'll only get vac advance at light throttle settings (such as at cruise). You won't have any vacuum at wide open throttle either (by design).
-Sam
Old 11-12-2005, 04:50 PM
Thank you very much for the information.
Old 11-12-2005, 05:54 PM
moparts moparts is offline
Most GM vehicles run manifold vac at dist. This lets you set a low base timing for easy starts and then pulls timing up so that engine runs good at idle. This really helps on higher compression engines.
20 foot 75 hp good time at the lake
Old 11-12-2005, 08:48 PM
When I pull the vacuum hose off the dist end while the engine is running it dies,that is'nt suppost to happen.This tells me that the vacuum hose from the dist to the carb is hook up wrong on the carb end.I have only two vacuum ports on the carb,one in the back of the carb on the bottom and one on the left front.The choke is hook up to the left front port.What gives here?
Old 11-12-2005, 09:50 PM
If you plug the vac. leak when you pull the hose off does it still die? If so you can set dwell with the vac hooked up, then if you have to you can raise base idle to get the car to run good enough with the vac unpluged from the dist. to set the base timing. Then it should be a matter of adjusting the carb after dwell and base timing are set.
Old 11-22-2005, 12:57 AM
booklearner booklearner is offline
Hi GTAA,
It sounds to me like several things are wrong here. Typically you want the distributor vacuum advance connected to the ported (not "constant" or manifold) vacuum source. Also, typically, the choke pull off is connected to the manifold vacuum source, not the weaker ported source.
So, I think there are three things wrong here.
1. The choke pull off needs to be plumbed into the manifold source at the back of the carb.
2. The dist. vacuum advance needs to be connected to the ported source (front left?) of the carb (NOT the constant vacuum source).
3. The static timing on the distributor needs to be advanced (the distributor moved) becuse the vacuum advance was incorrectly connected to the manifold vacuum (causing the timing to be "right" in a wrong way.) The strong manifold vacuum applied to the vac. advance was causing the timing to be right, but it isn't the correct way to have it set up. It suspect it wasn't like this from the factory.
Once you get all this done, set the "static" timing (with the vac advance disconnected and plugged) to be around 10 degrees (give or take). Then when you connect the vac. advance back up (to the PORTED source), the timing shouldn't change much. Now, as you speed up the RPMs of the motor, the ported vacuum will come up and add more timing with the vacuum advance. As you approach full throttle the ported source will fall off. Remember that fuel burns at a fixed rate, so you only need (or want) so much timing at idle.
The motor would definitly die at idle the way it was setup with the vac. advance connected to the constant (manifold) vacuum. If fact, it makes perfect sense.
I hope this helps and doesn't confuse too much.
-BL
Old 11-23-2005, 06:22 AM
Thanks for the information I'll try that.I'll get back with you and let you know if it worked or not.
Old 11-23-2005, 08:28 AM
Kurt S Kurt S is offline
I disagree.
Vacuum advance should most definitely be connected to manifold vacuum, not ported.
Here's a ton more info, written by JohnZ (from http://www.camaros.org/forum/index.php?topic=64.0):
You'll note a major improvement in cooling performance, throttle response, and fuel economy by connecting your vacuum advance unit to a full manifold vacuum source (the production configuration had it connected to "ported" vacuum, which provided zero vacuum advance at idle). Retarding the timing will make cooling problems worse - that's what the "ported" vacuum does already; you want all the vacuum advance you can get at idle to reduce EGT.
TIMING AND VACUUM ADVANCE 101 (from October/November 2003 issue of "Corvette Enthusiast" magazine, written by JohnZ)
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
Kurt S - CRG
Old 11-23-2005, 11:49 AM
I installed new points condensor,plugs,wires,cap rotor.I set my dwell at 30 and my timing at 10 and ajusted the air fuel mixture.At an idle it ran great I snaped the throttle acouple of times and it responded pretty good.I drove the car and under normal driving it was great but when I nailed the throttle it feal on its face,it was hestitating big time.It did'nt backfire or anything like that.At this time the vacuum advance hose was hook to main vacuum in the back of the carb.So I switch the vacuum hose to the vacuum port on the left front of the carb,same thing happened it feal on its face.I'm thinking that I have a carb problem?Any suggestion would be appreciated.
