#11
My guess is that the 7115 cranks were probably used with the heavier open chamber 12.5:1 domed pistons for the L88 and ZL1 since the counterweights are slightly wider for balancing purposes. The 396 and 427 11:1 closed chamber pistons were lighter and worked with the narrower counterweighted 6223 crank.
Paul
70 Camaro LA Z-28 03B Citrus Green LT-1 M-40 3.73's 69 Camaro X-77 Z-28 10C Cortez Silver M-21 3.73's Deluxe Project X - SOLD 69 Camaro X-77 Z-28 01B Garnet Red w/Black top, M-20 3.73 Deluxe Houndstooth |
#12
I checked with someone i know who has taken alot of virgin motors apart and here is what i was told,it kind of falls in to what i had stated.Hope it helps ! 1967 435hps taken apart for the first time have had 7115 cranks with very few exceptions, 2 bolt main 427 motors usually had 6223 cranks,only corvette w 2 bolt mains ever used a 7115 . 427 COPO 427s mostly had 7115. Impala and passenger 427 hi perf used 6223 exclusively,this is from a pool of around 150 motors that were taken apart seemingly for the first time. As far as L88 and ZL1 ,only 3 L88 and 1 Zl1 were taken apart like this and all had 7115, Still have yet to see a 6223 crank even in a new crate motor from the late 70s as has been claimed,although certainly a possibility 8 nos assemblys from the 70s have had exclusively #7115 cranks " There you go !
Kevin 1970 Chevelle Droptop Period Correct Speed Parts 482 BBC, M22 or TH400? Day 2 Super Stock Rocks |
#13
Hi Kevin,
I don't want to bang heads with you here but I have not heard of one COPO 427 with a factory '7115 crankshaft. Several members here own them, perhaps they would care to elaborate. Additionally, I addressed this very issue last year on the NCRS forum and walked away with the understanding that the '6223 crankshaft was the common crankshaft in use at the time. It existed in various forms: standard, cross-drilled and cross-drilled/tufftrided in both 396 & 427 applications. The comment about the '7115 being used in conjunction with the 12.5:1 pistons seems quite plausible to me.
Kevin,
I did learn that evidently some of the '67 L/71's used the '7115 crankshaft as you indicated. That appears to possibly be a 1967 situation only - though. Steve
Has anyone heard of using a tall block spacer to match up or transition an oval port manifold with rectangular heads? Hey Nuch, what was that about using a rectangular manifold with oval heads?
#16
Michael,
Not sure about using an oval port intake with rectangular port heads. Doesn't make much sense. The oval ports are good up to about 6,500 and that is about where the rectangular port heads are getting started. I would think that the intake would reach the choke-off point just about when the heads were ready to go-for-it. From the number of posts here and on the NCRS forum, it's evidently quite common to mount a rectangular port intake up against oval port heads and get good HP up to about 6,500 RPM's. The bolt pattern is exactly the same so there is no problem there. Just use the rectangular port intake gaskets if you do this. I will try this myself one day. It's got my curiousity peaked. ![]() Steve
