ls6 fuel line
Could someone please post pictures of the fuel pump-carb fuel line setup where it connects to the brass fitting on the intake and then runs back to the secondary metering plate? The stainless one that I bought from a vendor is way off,it appears that the short piece of line that connects the front metering plate to the brass t fitting is just too long.It's length causes the fitting to be over so far that I think it may hit the valve cover,which in turn cause the secondary line to not line up with the fuel line brace.I double checked the tag on the vendor's back and it says it's for my engine{ls6 w/long pump}
