Old 01-26-2008, 05:32 PM
Steve Shauger's Avatar
Administrator
Default Re: Original stamping?
so i can understand this, how is the P in this stamping SEPT
P---Muncie assembly plant
9---1969 model year
P---Sept.
10--10th day of Sept.
He said "the NUMBER AFTER the "P" is model year. You decoded it perfectly above. As has been stated the 9 represents the model year vehicle this was used in , Not the calendar year it was built.
www.yenko.net
www.vintagecertification.com
Old 01-27-2008, 03:17 PM
HiHorse HiHorse is offline
P9P10 Muncie build decodes as...
9---1969 model year
P---Sept.
This is an early build trans, Sept. 10th of 1968 for use in a 1969 model year car...
It has no A-B-C ratio designator because that didn't start until the end of Sept. 1968 calendar year, a little more than a month later... Hope this helps... Crash
I have a Muncie with build date P9R03B, this one is Oct 69 based on the VIN derivative.
Old 01-27-2008, 08:46 PM
Administrator
9---1969 model year
P---Sept.
I would bet that the trans came out of a 69 camaro, since production was extended until Nov of 1969. Again camaros built in this time frame were still considered 1969 model year camaros. The VIN is what identifies the year in which it was built. The Vin most likely starts with 69xxxx or 70xxxx.
www.yenko.net
Old 01-27-2008, 11:58 PM
Administrator
This is stamped PR14B (Muncie, Oct 14th, M21) The 702xxx VIN derivative indicates trans was built for a Norwood camaro built in late Oct of 69.
Old 02-02-2008, 03:10 AM
9---1969 model year
P---Sept.
Actually this is from my 1969 Corvette built Nov. 69
Old 02-02-2008, 07:07 AM
crash crash is offline
1969 model year Corvette's was a 16 month production(Sept 1968 thru Dec. 1969) like 1969 Camaro's... Hope this helps... Crash
