Old 04-08-2008, 06:11 AM
micky69396 micky69396 is offline
Default Re: Teflon tape on flare fittings
Its about as common as trunk weatherstrip installed the wrong way. That dont work either.
Micky Hale
Hale Performance Consultants
Engine Parts Sales & Service
Old 04-08-2008, 06:15 AM
Or upside down cowl induction seals?
Old 04-08-2008, 06:44 AM
L78steve L78steve is offline
Teflon tape is helpful on the threads of bleeders.You can vacumme bleed w/o pulling air down the threads.
Old 04-08-2008, 04:50 PM
YENKO DEUCE REGISTRY's Avatar
It just makes me laugh every time I see it...BKH
Ditto! Along with GM labels with bar codes still affixed to various parts,
Marlin
Old 04-08-2008, 04:59 PM
juliosz's Avatar
juliosz juliosz is offline
The only time I've seen teflon tape or thread sealer used on flare fittings is when someone uses stainless steel lines. As most of you know, they can be a bear to initially seat and seal without drips. I think many folks do it out of frustration. The slick setup for stainless fuel lines is a copper insert that goes inside the flare. A mechanic who retired from a Caddy dealer after many years had a bunch in his tool box. I don't know if you can still get them anywhere but they sure made sealing up a 427/435 vette with stainless fuel lines pretty easy.
Old 04-09-2008, 04:39 PM
Belair62 Belair62 is offline
Maybe if they made the fuel lines sets in the U.S instead of China,Hong Kong or Mexico they would seal better ?
Old 04-09-2008, 06:16 PM
I had a problem getting the lines to seal on the 69 Z... I had to seat all the fittings separately anf then install the whole setup... they leaked like a seive before...
Survivors, restored cars, &amp; other photos
Old 04-09-2008, 08:28 PM
TDW TDW is offline
Without a doubt they would be better. You wouldn't believe what I am going through buying ONLY American made parts for the Nomad Gasser project. The only thing I HAD to buy imported were the ET 10 spoke wheels, and it killed me to do that.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 04-09-2008, 09:43 PM
The inside taper on the tubes seems to be the problem... they are misformed or not fully formed.
The only way I could get them to seat was to take them one at a time and snug it down... then rotate the line 360 deg a few times and it would get looser... snug again... and repeat a few times... then I tightened them up on the car... viola no leaks! (you may be able to use a dbl flare tool and reform the inside tapers)
Old 04-09-2008, 11:18 PM
P.J. P.J. is offline
As some of you know the reason that the stainless wont seat properly is that its too hard. They should heat treat the metal tube so that it softens it to the sam RC as the steel ones.It would then seat great and look great.
DA-----HHH.
PJ
