Old 11-29-2024, 12:19 PM
dykstra's Avatar
dykstra dykstra is offline
Amazing!!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
OneStopRestoration (11-30-2024)
  #212
Old 11-30-2024, 06:30 PM
OneStopRestoration OneStopRestoration is offline
Default Front Suspension
As i assembled the front suspension my fear is it will be coming part post restoration for ride height adjustment. Looks super clean and no scuffs or scratches. Happy i got to use over the 2 piece rotors.
The Following 13 Users Say Thank You to OneStopRestoration For This Useful Post:
big gear head (12-01-2024), chevyman0429 (11-30-2024), Dave Rifkin (12-01-2024), dykstra (12-01-2024), gtomike1967 (11-30-2024), olredalert (12-01-2024), PeteLeathersac (12-14-2024), ragtop (12-01-2024), RPOLS3 (12-01-2024), Tenney (12-01-2024), Tuna Joe (12-14-2024), Woodrock (12-03-2024), Zman1969 (12-02-2024)
  #213
Old 12-10-2024, 09:53 PM
Default Engine back from the Machine Shop
Picked up the engine yesterday. I think this about the closest thing a car enthusiast can get to the feeling you had as a kid on Christmas morning. Engine is 40 over, with 38 CC domed pistons. Roller cam with a grind very close to stock l78. Same one I used on the 66 SS i just finished. Heads are milled way down so the chambers are 111ccs. For the guys that noticed yes there zl1 heads. All in all should be around 10.8 to 1 when done but I need to do some checking on how far the pistons are in the hole. Assembly to come!
The Following 15 Users Say Thank You to OneStopRestoration For This Useful Post:
69M22Z (12-10-2024), Dave Rifkin (12-12-2024), dykstra (12-10-2024), L78_Nova (12-11-2024), McCune (12-11-2024), olredalert (12-10-2024), PeteLeathersac (12-14-2024), ragtop (12-10-2024), Roger M (12-15-2024), RPOLS3 (12-12-2024), scuncio (12-10-2024), SMS (12-30-2024), Tenney (12-11-2024), Tuna Joe (12-11-2024), Zman1969 (12-16-2024)
  #214
Old 12-10-2024, 11:18 PM
dykstra's Avatar
Oh yeah!!!!!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
Old 12-14-2024, 01:30 PM
chevyman0429's Avatar
chevyman0429 chevyman0429 is online now
Originally Posted by OneStopRestoration View Post
Drivers quarter is now on. Happy with the door gap and face fitment. If you handnt already noticed i replaced the entire rear panel as well because of the trunk gutter being all mangled and the fact the the drivers side was wrinkled up and just couldnt be brought back. Got nice fitment beteween the deck lid, quarter, and quarter extension on to the passenger side now.
Before you do your quarter panel replacement do you replace the body bushing first like so many people suggest to do or leave it as is and replace quarters? Thanks an once again thank you for taking the time to share your progress with us all!
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 12-14-2024, 03:00 PM
I double check to make sure there is no major damage or rot. If I do find questionable bushings I just put metal spacers back in during assembly. The frame is kinda like a wet noodle as it is, especially in the rear. Its obviously ideal all body points touch down evenly but i have had cars where its not, and I didnt do any major panel replacement.
Old 12-14-2024, 03:03 PM
Default Shifter - Hurst
I have deviated on 68-72 cars with the shifter because the muncie to me is just not ideal. I grabbed an old hurst setup, and restored it. One of the trick things to do is machine all the bushings for the rod pin points so its super tight.
69M22Z (12-14-2024), chevyman0429 (12-14-2024), Dave Rifkin (12-14-2024), dykstra (12-14-2024), L78_Nova (12-16-2024), olredalert (12-14-2024), PeteLeathersac (12-14-2024), ragtop (12-14-2024), RPOLS3 (12-14-2024), Tenney (12-15-2024), Tuna Joe (12-14-2024), Woodrock (12-15-2024), Zman1969 (12-16-2024)
  #218
Old 12-15-2024, 09:55 PM
Default M21 Muncie 4 Spd
Found a correct 69 M21 case date very close to the car with no Vin. Just basic clean up and blast and then recondition the alum parts to look new.
Most of the muncies builds I just get all new gears along with the overhaul kit. Dad taught me alot of tricks for assembly and preparation of the parts to ensure buttery smooth shifts, even brand new.
Assmebling the main shaft into the case can get frustrating, as this one gave me some problems. I finally figured it all out
The Following 14 Users Say Thank You to OneStopRestoration For This Useful Post:
66BoxNova (12-15-2024), 69M22Z (12-16-2024), Dave Rifkin (12-16-2024), dykstra (12-15-2024), L78_Nova (12-16-2024), mhurd (12-16-2024), napa68 (12-16-2024), PeteLeathersac (12-16-2024), ragtop (12-15-2024), RPOLS3 (12-16-2024), scuncio (12-16-2024), Tenney (12-16-2024), Tuna Joe (12-16-2024), Zman1969 (12-16-2024)
  #219
Old 12-16-2024, 03:47 AM
Tuna Joe Tuna Joe is offline
I’ve had my Muncie out of my Corvette for months now.
I’ve watched the Muncie files on YT, read Paul’s book but I still can’t bring myself to tear it apart.
I’ve never rebuilt a transmission so I’m apprehensive.
How do you get the case to look so good?
Old 12-16-2024, 01:10 PM
I can understand being apprehensive. Most of the assembly isnt too bad. That said you need a press and patience for a few of the learn by doing not by watching tasks. Loading up the cluster shaft with the bearings via some assembly grease and having a undersized pin is a must. When you braing the main shaft and center bearing plate into the main transmission with the gasket can be tedious but not impossible. The best advice is dont force anything and be willing to take something back apart when its not going on right.
In light of all of that as you can see in the pictures I wear gloves to keep my case work clean. Im gonna send you a PM about case prep
The Following 4 Users Say Thank You to OneStopRestoration For This Useful Post:
dykstra (12-16-2024), PeteLeathersac (12-16-2024), ragtop (12-16-2024), Tuna Joe (12-16-2024)
