Old 10-06-2023, 12:30 AM
jbtech's Avatar
jbtech jbtech is offline
----I wonder if you offered another rebuilt big block for this one that obviously needs rebuilding if that might peek his interest. If he's thinking of building something (even if he doesn't) he would have an engine ready to go. What do you think?.....Bill S
The engine is rebuilt and in a running Base Camaro RS. They rechromed the valve covers, use all original components with exception of arp head bolts. When I first spoke to the the current owners they have even considered pulling the motor because of the perceived value of the engine and constant maintenance.
I'm thinking when my car is up and running and I have that MQ engine done I'll do what Chuck (427 King) has advised and do a one time sweet offer of perhaps an engine plus cash plus cost of a swap, I just hope they are open to it.
My car has the docs, the rear, the history, and the hard to find parts. If the original engine can be reunited it will greenlight a restoration and I'd like to show the car at nationals before and after a resto with the original motor sitting beside the car (pre resto). What a story that would be and how cool would it be for the owners of the original motor to be a part of it. They have taken great care of the motor and I'm lucky it's even still around.
Jose Betancourt
67 Camaro L78
The Following 6 Users Say Thank You to jbtech For This Useful Post:
1967Z28 (10-06-2023), big gear head (10-06-2023), dykstra (10-06-2023), napa68 (10-06-2023), olredalert (10-06-2023), RPOLS3 (10-07-2023)
  #242
Old 10-06-2023, 12:51 AM
jbtech's Avatar
Bruce turned 81 a couple weeks ago and going through his things anything he finds car related he will set aside.
He says there is a chance the POP may have been in the glove box when he sold the car to John Goss who was a teenager at the time.
He also provided clarification on the air cleaner, he made a duct that screwed directly to the cowl and stuck out a few inches, the inner tube went over both that duct and the air cleaner base duct as a slip fit. When he first mentioned the inner tube I thought he meant that the inner tube screwed directly to the cowl. He also said the duct that was screwed to the cowl may have been on the car when it was sold. It should be easy to make but for now I'll run a stock air cleaner assembly.
I'm working on making my own 67 L78 fuel line but for now I modified a 66 Corvette fuel line to work with the service ZL1 fuel pump. I added an inline fuel filter.
Jose Betancourt
67 Camaro L78
1967Z28 (10-06-2023), dykstra (10-06-2023), olredalert (10-06-2023), SuperNovaSS (10-06-2023), Tuna Joe (10-08-2023), Zman1969 (10-11-2023)
  #243
Old 10-11-2023, 01:42 AM
jbtech's Avatar
I temporarily installed the front clip and it feels good to see it resemble a car again. It will come off to install the emblems and button up the engine bay before firing it up.
Jose Betancourt
67 Camaro L78
The Following 23 Users Say Thank You to jbtech For This Useful Post:
169indy (10-11-2023), 1967Z28 (10-11-2023), 69M22Z (10-11-2023), big gear head (10-11-2023), carnut4life (10-11-2023), chevyman0429 (10-11-2023), Dave Rifkin (10-12-2023), dykstra (10-11-2023), gtomike1967 (11-19-2023), jer (10-11-2023), John (10-14-2023), juliosz (10-11-2023), L78_Nova (10-11-2023), napa68 (10-11-2023), Oldss (10-11-2023), olredalert (10-11-2023), PeteLeathersac (10-11-2023), Pro Stock John (10-12-2023), Stihl (10-26-2023), SuperNovaSS (10-11-2023), Tuna Joe (10-11-2023), Xplantdad (10-11-2023), Zman1969 (10-11-2023)
  #244
Old 10-11-2023, 10:48 AM
dykstra's Avatar
dykstra dykstra is offline
Awesome!!!
Dave Dykstra
2013 Corvette Grand Sport 60th Anniversary
NCRS#66003
“Education is what you get when you read the fine print. Experience is what you get if you don’t.”-Pete Seeger
Dykstra Motorsports
jbtech (10-14-2023)
  #245
Old 10-17-2023, 02:54 PM
jbtech's Avatar
I bought another car from a member here Fred Yates. So I've been cleaning up and making room for the El Camino and parts.
This is the first time the Camaro has been outside in a while. The small parts I needed to start the car have arrived now it's just a matter of labor.
I have an Instagram profile and made a short reel of the car here:
https://www.instagram.com/reel/CyYx3...RlODBiNWFlZA==
Bruce says it brings back memories to see the car coming together. Hopefully I'll go to OH with the car soon.
Jose Betancourt
67 Camaro L78
The Following 17 Users Say Thank You to jbtech For This Useful Post:
1967Z28 (10-17-2023), Andy (10-17-2023), big gear head (10-17-2023), carnut4life (10-18-2023), chevyman0429 (10-17-2023), dykstra (10-18-2023), Hawkeye (10-18-2023), John (10-17-2023), L_e_e (10-17-2023), napa68 (10-17-2023), Oldss (10-19-2023), olredalert (10-17-2023), PeteLeathersac (10-17-2023), RPOLS3 (10-17-2023), Stihl (10-26-2023), SuperNovaSS (10-18-2023), Zman1969 (11-22-2023)
  #246
Old 11-19-2023, 09:53 PM
jbtech's Avatar
Cooling system installed, correct driveshaft installed. I swapped the yoke to fit the larger output of the '70 M22. This driveshaft was removed from an L78 race car. I also removed the correct early shroud from the same car.
Jose Betancourt
67 Camaro L78
The Following 15 Users Say Thank You to jbtech For This Useful Post:
169indy (11-20-2023), 1967 4K (11-20-2023), 1967Z28 (11-21-2023), 69M22Z (11-19-2023), big gear head (11-20-2023), dykstra (11-20-2023), L72copocamaro (11-20-2023), L_e_e (11-19-2023), napa68 (11-20-2023), olredalert (11-21-2023), PeteLeathersac (11-20-2023), RPOLS3 (11-21-2023), Woodrock (11-20-2023), Xplantdad (11-19-2023), Zman1969 (11-20-2023)
  #247
Old 11-21-2023, 01:00 AM
jbtech's Avatar
It's alive! I used the 10 10 10 method for break in. Nothing broke, no leaks, steady oil pressure at 65psi. I still need to tune it. This is the first time since '83 this car had a running engine.
https://www.instagram.com/tv/Cz4u93i...RlODBiNWFlZA==
https://youtu.be/j0GpBW5Ub2g?feature=shared
Jose Betancourt
67 Camaro L78
The Following 20 Users Say Thank You to jbtech For This Useful Post:
169indy (11-21-2023), 1967Z28 (11-21-2023), 69M22Z (11-21-2023), big gear head (11-21-2023), BlackL78M22Nova (11-21-2023), carnut4life (11-21-2023), dykstra (11-21-2023), Hawkeye (11-21-2023), juliosz (11-25-2023), L78_Nova (11-21-2023), L_e_e (11-21-2023), napa68 (11-21-2023), Oldss (11-22-2023), olredalert (11-21-2023), PeteLeathersac (11-21-2023), R68GTO (11-21-2023), scuncio (11-21-2023), Too Many Projects (11-25-2023), Xplantdad (11-21-2023), Zman1969 (11-22-2023)
  #248
Old 11-21-2023, 10:37 AM
dykstra's Avatar
Congrats!! Sounds great!!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
The Following 2 Users Say Thank You to dykstra For This Useful Post:
jbtech (11-21-2023), napa68 (11-22-2023)
  #249
Old 11-21-2023, 11:20 PM
jbtech's Avatar
After some adjustments. Getting closer!
https://www.instagram.com/reel/Cz7Xp...RlODBiNWFlZA==
Jose Betancourt
67 Camaro L78
The Following 5 Users Say Thank You to jbtech For This Useful Post:
dykstra (11-22-2023), juliosz (11-25-2023), L_e_e (11-22-2023), napa68 (11-22-2023), Oldss (11-22-2023)
  #250
Old 11-21-2023, 11:34 PM
Looks great, keep rockin!
The Following 2 Users Say Thank You to PeteLeathersac For This Useful Post:
dykstra (11-22-2023), jbtech (11-27-2023)
Tags
1967, 396 ss, l78 camaro
