Old 01-06-2024, 07:38 PM
Zedder's Avatar
Zedder Zedder is offline
Awesome!
Mark
The Following User Says Thank You to Zedder For This Useful Post:
jbtech (01-09-2024)
  #262
Old 01-06-2024, 09:24 PM
I want a ride!
Jason
The Following 4 Users Say Thank You to SuperNovaSS For This Useful Post:
jbtech (01-09-2024), Jeffp920 (01-07-2024), PeteLeathersac (01-10-2024), Zman1969 (01-17-2024)
  #263
Old 01-10-2024, 01:59 PM
BJCHEV396's Avatar
Great job Jose! Keep it up!
jbtech (01-11-2024)
  #264
Old 01-10-2024, 02:00 PM
BJCHEV396's Avatar
Originally Posted by SuperNovaSS View Post
I want a ride!
Jason
I wanna drive it,lol!
jbtech (01-11-2024)
  #265
Old 01-10-2024, 04:18 PM
1967Z28's Avatar
1967Z28 1967Z28 is online now
Just an FYI in case it matters to you but this is the assembly line correct style of shift boot that should be in the car. The one in there now is a generic service replacement piece. https://www.ebay.com/itm/26441459069...Bk9SR_r918WeYw
The Following 3 Users Say Thank You to 1967Z28 For This Useful Post:
jbtech (01-11-2024), JKZ27 (03-30-2024), John (01-11-2024)
  #266
Old 01-11-2024, 03:08 PM
jbtech's Avatar
jbtech jbtech is offline
I want a ride!
Jason
You should drive it too!
I had no idea! Thanks!
Jose Betancourt
67 Camaro L78
The Following User Says Thank You to jbtech For This Useful Post:
1967Z28 (01-11-2024)
  #267
Old 01-16-2024, 05:20 PM
jbtech's Avatar
I drove the car to a local shop in Salinas who was able to perform an alignment with the specs I provided. After this my confidence in the car was enough that I installed the wiper motor and took it out for a morning drive. However, there are a few gremlins that have popped up.
Turn signal indictors stopped working. I ran ground straps, I did everything and it turns out the NEW bulbs do not work like originals. I simply swapped bulbs for originals I took from a spare cluster and the problem was solved.
Original rotors are warped. I may bite the bullet and buy the 2 piece repops. I already had the original rotors turned.
The original gm steering box binds and I can still drive the car but I will need to address this.
I connected the distributor to manifold vacuum and finally got the idle set where it fires right up, idles at 850 when warm and produces 15 inches of vacuum. The factory tach reads too high a few hundred rpm and I used the timing light to set the rpm. Because it reads too high I'm going to go ahead and connect the mechanical tach.
The NEW voltage regulator was bad out the box, swapped for a April 67 original and solved the problem
New problem I have is around 65 mph I feel the car slightly vibrate left to right. I'm suspecting the driveshaft, perhaps it was damaged while being shipped.
However, the car sounds great and when I launch it I feel like I'm guiding a missle. Per recommendations from Joe on this site, I'm running the pro tracs at 20-22psi and It has made a big difference in how the car performs.
Next I want to finish up the interior, and fix the gremlins.
If you have instagram my username is josebetancourt831 I try to add photos and clips there as well.
Jose Betancourt
67 Camaro L78
The Following 15 Users Say Thank You to jbtech For This Useful Post:
1967 4K (01-16-2024), 1967Z28 (01-16-2024), big gear head (01-17-2024), chevyman0429 (01-16-2024), Dave Rifkin (01-16-2024), jer (01-17-2024), John (01-18-2024), L_e_e (01-16-2024), napa68 (01-16-2024), olredalert (01-17-2024), PeteLeathersac (01-16-2024), RPOLS3 (01-24-2024), Stihl (03-18-2024), Xplantdad (01-16-2024), Zman1969 (01-17-2024)
  #268
Old 01-16-2024, 06:57 PM
luzl78 luzl78 is online now
Balanced driveshaft would make a world of difference.
Old 01-16-2024, 07:02 PM
1crossram 1crossram is offline
Warped rotors could also cause issues with wobble but you have done great progress and I enjoy seeing your posts.
1967 Camaro RS/SS convertible Butternut yellow with black power top, factory AC
Rebuilding 1967 RS headlight motors
Old 01-16-2024, 07:28 PM
There is a potentiometer on the back of the tach behind this sticker to adjust the rpm reading. Just be careful, the potentiometer can be fragile after all these decades.
Jason
The Following 6 Users Say Thank You to SuperNovaSS For This Useful Post:
dykstra (01-16-2024), jbtech (01-22-2024), olredalert (01-17-2024), PeteLeathersac (01-16-2024), RPOLS3 (01-24-2024), Xplantdad (01-16-2024)
Tags
1967, 396 ss, l78 camaro
