Old 03-17-2009, 04:13 AM
Chevy454 Chevy454 is offline
Default Re: 074 head repair
IIRC, Indy Cylinder Head used to be where all the bad heads went...
Old 03-17-2009, 04:42 AM
Alss's Avatar
Alss Alss is offline
Head is not that bad...water is in the heat crossover due to drilling the exhaust stud too deep. Spoke with several shops today and we all agree no harm in letting the water be in the heat tube..going to block it off at the manifold with a stainless plate under the intake gasket..should seal the water out of the intake and Im good to go..will keep everyone posted on how it works out..thanks
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 03-17-2009, 05:06 AM
beater68427 beater68427 is offline
Heat cross over is on the intake side, exhaust mounting flange well thats on the other side, I'm guessing your speaking of the exhaust rocker arm stud I would fill the heat cross over with epoxy if this the case.
Old 03-17-2009, 06:11 AM
1randy 1randy is offline
RAY`s CRACK REPAIR.
Ray Shepherd, owner
shop: 502-645-7444
270-358-0934
he is one of the best i have seen !!! he has fixed some heads i messed up realy bad that i thought were not repairable. been using him for 15 years.
Old 05-29-2009, 06:28 PM
Harry P Hunter Harry P Hunter is offline
Alss: Curious how this repair worked out?
Harry P. Hunter
Old 05-29-2009, 11:12 PM
Alss's Avatar
Harry P. Hunter
so far so good..no leakages.motor is a bear!!
