Old 07-28-2015, 03:15 AM
watk69 watk69 is offline
Default Re: 1969 Camaro Tie Down
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 68l30</div><div class="ubbcode-body">Cross the straps....it won't move.
BIG </div></div>
On a Concours type car where do you do that and not pinch or mash brake lines, hoses, brackets etc and keep from marking up axle housing on a 69 Z/28? I was trying that on ride home with the car and gave up. Seemed like straight back underneath the brake lines was my only option, hence the switch to wheel baskets since then
Clif
________
'69 Dusk Blue Z/28
'15 Red Hot Z/28
Old 07-28-2015, 01:12 PM
68l30's Avatar
68l30 68l30 is offline
I go thru the traction bars on my Day two 68, I use to go in front of the axle around the leaf spring mount and down and back on cars without. It won't move or scratch...Same with the front, cross and leave the winch cable attached to the sling with a bit of slack. I let the tie downs hold the car. Never have they gotten loose or has the car moved. Both on a open trailer and enclosed.
BIG
