Old 11-11-2016, 08:20 PM
sYc sYc is offline
Default Re: Sheared off bolt
I too am confused why removing the other stud will not allow the housing to slip off the broken stud, but if the case
Lay a washer on the housing, welding through the hole in the washer to bolt. Then weld a nut onto the washer and gently work it out.
Tom Clary
Old 11-11-2016, 10:08 PM
Default Sheared off bolt
I was expecting the 'stat housing coming off was a given and the problem was dealing w/ the protruding broken bolt left behind?
[img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 11-11-2016, 11:48 PM
DW31S's Avatar
DW31S DW31S is offline
Maybe I'm confused, but isn't the broken bolt &quot;time-welded&quot; to the housing?
Old 11-12-2016, 12:03 AM
ban617 ban617 is offline
I would think if you heated the T stat housing it would come off..
Old 11-12-2016, 12:40 AM
Tracker1's Avatar
Tracker1 Tracker1 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DW31S</div><div class="ubbcode-body">Maybe I'm confused, but isn't the broken bolt &quot;time-welded&quot; to the housing? </div></div>
Yup.
I ain't nobody, dork.
Old 11-12-2016, 05:14 PM
69 Post Sedan's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Tracker1</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DW31S</div><div class="ubbcode-body">Maybe I'm confused, but isn't the broken bolt &quot;time-welded&quot; to the housing? </div></div>
Yup. </div></div>
Yes.....the bolt is steel and the T-stat housing is aluminum whichhave become corroded together as they are dissimilar metals.
As stated above, heat and some sort of penetrating oil will work.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 11-12-2016, 05:49 PM
VintageMusclecar's Avatar
Why not center punch in the middle of the broken bolt and drill it out starting with a 1/8&quot; bit and working your way up until the wall thickness of the remnant is thin enough to either break off or break free from the housing?
It's a tedious, pain in the ass job but I've done it more times than I can count and it works.
Old 11-12-2016, 05:51 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">Why not center punch in the middle of the broken bolt and drill it out starting with a 1/8&quot; bit and working your way up until the wall thickness of the remnant is thin enough to either break off or break free from the housing?
It's a tedious, pain in the ass job but I've done it more times than I can count and it works.</div></div>
^^^^^^ if all else fails ... been there, done that! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
