Old 01-24-2024, 11:15 AM
69 Post Sedan's Avatar
I’m also a big fan of the clattering of a solid lifter car., I’d do anything I could to run at least a solid roller as it’s the easiest to do the initial startup but if you can find a good solid flat tappet solid lifter supplier, I’d try that route.
I spoke to one engine builder and he ONLY uses USA made Johnson Lifters for his builds…..but it looks like they only make roller lifters. So if you decide to go with a solid roller, maybe check them out.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-24-2024, 05:00 PM
Originally Posted by Crossbreed383 View Post
I responded to a thread here not long ago explaining the issues with most cam failures these days but no one seemed responsive ??
Oh and I work at BTR and do all the custom cam work as well as run the Spintron and engine dyno from time to time when help is needed .
We are grinding cams inhouse but aren't doing anything BB although I spec and have them ground for customers all the time
Nick E.
Here’s the thread from 10/23 w/ comments as Pg.#2 Post 14 and on…
https://www.yenko.net/forum/showthread.php?t=177064
RobR (01-24-2024)
