#371
I have spoken with this owner. His other car is the one I got all my measurements from.
![]() Very small world, this 507 planet! Cheers Dave |
The Following User Says Thank You to A12pilot For This Useful Post: | ||
Lee Stewart (06-25-2022) |
#372
Squares? Check. Indigimous levels? Check. Straight edges, micrometers, and gravity compensators? Check-a-Roo!!! Welp, time to weld up some stuff and see if it resembles a front end.
![]() Starting off reading the instructions would be a great idea. But last I checked, that never helped any guy at any point in human existence. That comes right next to asking for directions when lost. Pfflllpp….you tell me when either one of those things actually helped out a problem. Let’s see. This should go here, but why is that angled? Does it angle backwards or frontways? Does the long thingy point backwards? This goes topwise, right? OK, OK, maybe just to set a good example for the lesser know’d people, lemme just bust out this paper packet here….. So after reading the instructions ten times and mocking things up that equal amount of times or more, I have a front end! I will say that the instructions were really detailed but did leave out a few things. There are way more measurements than I had anticipated and I’m glad I did things three, four, five times to make sure I was on the right track. Get it? Track? Front end? I know…..stupid. ![]() Remember, I’m starting from nothing so my front end frame rails aren’t anything but 2x4 stock. This will be a subframe that will be connected to the side rails, seamlessly I tells ya, forming the complete frame. So I set the measurements based off an inner frame rail dimension of 26-1/4” and a inflated tire size of 27-3/4" There’s a series of calculations that determine the notch size, distance, and spacing front to back on the rails. I set the axle centerline based on a distance from the front of the rails rearward. The crossmember gets placed rearward from the centerline which is marked on the rails. It’s a simple mathematical formula that I had jotted down in my notes shown here for thoughts who are curious…. ![]() Once level and square, I tacked it in place. Next comes placement under the front sheet metal. Using jacks, levels and the centerline marked on the fenders, I positioned the subframe in positioned and aligned it as close as I could. It didn’t have to be 100% accurate in placement since I don’t have it welded up to the main rails yet. But it needs to be square and level. But having it in the right space is a confidence booster for when I fit the wheels up and they actually fall in the wheel wells. Once that was all I placed correctly I then needed to tack the top hats on. It’s a simple process, really: 1. Measure 9/16th down from the outermost inner point of the centerline of the forward point of the coil over mount. 2. Using an angle indicator, scribe a line 3.27 degrees aftward from the previously described point. 3. Triangulate this with a point on the opposite side on the backend portion of the rearward top hat front shock inner mount. ![]() So after that simple calculation, a few tack welds and bingo….instant front end!!!! The wheels fit in the wells exactly as planned and everything is square and true. I’m extremely happy so far. Hopefully I can keep the momentum going for the rear. That’s going to require a whole other set of measurements along triangulatory longitudinal perpendicularousness. ![]() ![]() Cheers Dave |
The Following 11 Users Say Thank You to A12pilot For This Useful Post: | ||
67 Nova Boy (11-16-2023), big gear head (06-26-2022), carnut4life (06-26-2022), Dave Rifkin (06-26-2022), dykstra (06-27-2022), Hawkeye (06-26-2022), L78_Nova (06-27-2022), markinnaples (06-27-2022), olredalert (06-26-2022), Tenney (06-26-2022), Woj (06-26-2022) |
#373
Dave, I can see why you were excited about that front end kit. It looks to be perfect for this build. Keep up the good work!
#374
Thanks, Phil. Yes, it bolted up nicely. On the final trim out I’ll be making it look more factory without shiney polished parts and such. Heck, I may even add inspection marks!!
![]() ![]() ![]() I’m hoping the rear ships out this week. More to come… Cheers ![]() Dave |
#375
Wow. Next level stuff for sure. Makes the restoration work you've done look easy.
#376
Thanks, Jake!
![]() ![]() Up this week will be front frame to mid section joinification and floor pannous creatous! ![]() ![]() Cheers Dave |
Xplantdad (06-27-2022) |
#377
1968 Camaro Ex-ISCA Show Car - Sold ![]() On The Lookout For My Next Classic... John 10:30 |
#378
----Geez, Dave! you should be able to eclipse 150 horsies without even breaking a sweat with a 215 GM. Bet you could keep it smooth a reliable with around 300hp!!!.....Bill S
#379
Alrighty, moving right along. The front suspension is in place so now it’s time to join the front rails to the side rails. My frame rail/industrial pipe bender is in the shop getting fixed,
![]() The small triangles are the lower radiator mounts. One part of the suspension that I am still on the fence on is the steering. I don’t like the way the rack and pinion looks up front. Yet, the 507 does have the drag link in front versus behind. My initial plans were to switch out that system to a manual box of some kind and use the linkage to match. I haven’t welded the rack mounts on yet since I was sent the wrong end tie rod end links in my kit. This manual rack is centered and with a 60” track width does requires longer rods. I esplained’ this to the dude on the phone where I bought my kit and he says, “No, you need a rack extension, not longer tie rods.” To which I replied, “No, I need longer tie rod ends on both sides. The problem you are referring to is a result of an offset rack and improper steering Ackerman. My rack is centered which does not change the pivot points thus keeps the Ackerman angle intact. I need longer rod ends to reach the spindles.” So this goes on and on until a conference call happens with the tech who builds the kit and he says, “You need longer tie rod ends”. Ah, customer service. The next domino in the decline of societal values. Anyway, I have the right parts so now I just have to decide what I want to do. I’ll probably just use the rack for now and alter the lower fascia to hide the thing. Easy enough to do! For the rear I decided 4-link was the best way to go since I didn’t want to see any goofy leafs springs and a drop in Jag rear was just way too overboard for this. So just throw the rear in and weld up for bars to hold it in, right? ![]() ![]() ![]() ![]() So step one was to assemble the Currie 9” sporting 3.70s and a posi with 11” drum brakes. After that was assembled and positioned, I then bolted up the wheels. Then the problems started. ![]() ![]() Currie: [rrriing…..rrrrring……rrrrrrrrriiiiing] “Currie Enterprises, Get your Rear in General and start here! This is Stan, can I help you?” Me: “Yeah, hi Stan. I ordered a 9” rear for my project and it looks like I was sent the wrong bolt pattern axles and drums. It’s supposed to be a five on…” Currie: “May I have the order number?” Me: “…five and a half and…oh, yeah, Order is 543875JMFC” Currie: “Yes, what is the problem?” Me: “Yeah, as I was saying, I received the wrong bolt pattern axles and…. Currie: “You ordered a 5 on 5.5” bolt pattern.” Me: “I know, that’s what I’m trying to tell you, the axles you sent are wrong” Currie: “Those aren’t wrong, that’s what you ordered.” Me: “I know that’s what I ordered, you sent the wrong ones to me!” Currie: “Why would we send you the wrong axles?” Me: “Why would I call you to discuss my axles if they were the right ones? Do you think I just wanted to compliment you on how nice they were since I have nothing better to do?” So, after this “Who’s on First” round about, I finally have the right axles and drums coming this way. But in all seriousness, they were excellent to deal with unlike the front end people. It really was just a matter of a quick email with a photo and him saying, “What the….those ain’t right! We’ll ship the right ones out to you tomorrow with a prepaid label for the return.” Now that’s how you do it! Despite the set back, I’m continuing with the mock up and things are going well. More to come with details on how to set up a 4-link, why the links are positioned the way they are, and the decline of customer service. Cheers Dave |
The Following 9 Users Say Thank You to A12pilot For This Useful Post: | ||
67 Nova Boy (11-16-2023), big gear head (07-08-2022), carnut4life (07-08-2022), dykstra (07-08-2022), L78_Nova (07-08-2022), markinnaples (07-08-2022), olredalert (07-08-2022), PeteLeathersac (07-08-2022), RPOLS3 (07-08-2022) |
#380
Wow - again.
