Old 02-12-2012, 04:29 PM
talwell talwell is online now
Default Matching Numbers L89 Camaro
There is a car listed on eBay now that the owners says is a matching numbers car. The listing shows a protecto-plate and a window sticker showing the L89 option.
It is a nice car - the question I have is if it is a numbers matching car why does it have an "LI" stamped block and not a "JJ"?
http://cgi.ebay.com/ebaymotors/1969-CHEV...=item4600d70e00
Old 02-12-2012, 04:42 PM
Default Re: Matching Numbers L89 Camaro
Look closer, I think it does say "JJ". Unfortunately it is painted over. Conveniently the head gasket is blocking the surface of the block in the all important transition area.
Old 02-12-2012, 04:50 PM
Yes, I guess I was looking at the wrong angle. I can now see the "JJ" stamping but yes, as you say where the broach marks would be are covered by head gasket.
To me the protecto-plate and window sticker look very crisp and fresh for being 43 years old. Also, the handwriting style on the warranty book looks like a very modern style - I dont recall ever seeing anyone using this type of script print that many years ago. The window sticker has all perfect edges - not a single tear or deviation on it and any sticker that I have ever removed from a new car I found that nearly impossible to do. Maybe the glue back then was weaker than they use today.
Old 02-12-2012, 04:58 PM
the427king's Avatar
The window sticker looks like it was put on diamond plate and run over
No Fisher priced toys here
Old 02-12-2012, 05:51 PM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: the427king</div><div class="ubbcode-body">The window sticker looks like it was put on diamond plate and run over </div></div>
Also...The last six numbers of VIN on the window sticker should be stamped on ( not typed ). The stamped font is usually quite larger and not in line with the first part if the VIN.
Old 03-14-2012, 07:51 AM
Guest
Posts: n/a
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 1969L78Nova</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: the427king</div><div class="ubbcode-body">The window sticker looks like it was put on diamond plate and run over </div></div>
Also...The last six numbers of VIN on the window sticker should be stamped on ( not typed ). The stamped font is usually quite larger and not in line with the first part if the VIN. </div></div> There is an example in Jerrys book where the whole vin # is typed.
Old 02-12-2012, 06:10 PM
kwhizz kwhizz is offline
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 02-12-2012, 05:32 PM
bergy's Avatar
bergy bergy is offline
Chambered exhaust in October of '69 on a US delivered car!!!!!
Old 02-12-2012, 05:53 PM
SS427's Avatar
SS427 SS427 is offline
From what I remember, everyone was using 3 to 4 digits when abbreviating a state back then. Suck as Minn not MN or Cal NOT CA, ILL not IL. This POP is MD. Just a casual observation and not sure how Maryland was abbreviated back then.
Rick Nelson
Old 02-12-2012, 07:17 PM
I noticed that on the window sticker as well - fully typed vin. Here is a good window sticker:
