Old 12-14-2015, 11:10 PM
ssl78 ssl78 is offline
Default Re: 1969 Camaro L78 conv ( came from east coast)
Yes I already printed the form out I just need to get the form notorized saying the title is in my nane. I hope I am lucky enough to get something back. Bob you are the 2nd guy who said try a black light I will have to get one.
I had to change the headlight switch and it had a fuel line clamp holding the 2 lines together any body ever see that. The headlight switch in the picture is the new one I was putting in.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 01-01-2016, 11:28 PM
Does any body know the thickness of a 69 Chevy big block deck pad that hasnt been decked. The first shot is a block thats been decked the second is a non decked block but it is a 74 dated block.
Wouldnt this be a sure way of being able to identify a restamp
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 01-01-2016, 11:43 PM
WILMASBOYL78's Avatar
Interesting approach...seems logical. I'm sure the experts will let you know soon.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 01-02-2016, 12:49 AM
bbbentley's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ssl78</div><div class="ubbcode-body"> Does any body know the thickness of a 69 Chevy big block deck pad that hasnt been decked. The first shot is a block thats been decked the second is a non decked block but it is a 74 dated block.
</div></div>
My educated opinion is that would not give a conclusive answer. There are core shifts in castings and that is why some have thin cylinder walls on 1 side after a re-bore and also why the thrust surface where the cam is installed is off center often. Because of these shifts that pad probably falls into a range that could vary .100 (swag) whereas a deck may be as little as a clean up cut or a blueprint (zero deck height to piston tops). There are so many variables that nothing conclusive could be measured from that pad thickness,IMO.
FULL OWNER HISTORY
Old 01-02-2016, 12:26 AM
DarrenX33's Avatar
John leave the glue. It's X2.
1969 Z28
1972 Corvette
Old 01-02-2016, 03:11 PM
The back seat is back in already I didnt do anything with it. It would be nice to know what a lot of original pad thicknesses are.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 01-02-2016, 05:22 PM
----John,,,When I look at the pic of the vacuum lines and clamp I think I see splits on both those lines. I believe the clamp was a weird attempt to stop a vacuum leak......Bill S
Old 01-02-2016, 07:27 PM
black69 black69 is offline
Glad the black light worked. There is no evidence there was ever a 4 there. I see more of the 2 in the non black light shot (the top corner, clear enough to define the size of the character). I see the left top portion of the X show up in the black light photo. All in all, looks like an X2 vs anything else. Any doubt, the untouched heater box confirms that (to me). I would never touch that glue, either.
Old 01-02-2016, 09:50 PM
Bill thats very possible. I ended up taking the clamp off and trimming back the hoses before I installed the new one. Bob I didnt want to fool around with the glue I just left it.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 01-02-2016, 12:06 PM
bergy's Avatar
bergy bergy is online now
I agree. The pad dimension is established in the machining operation that locates the block off of &quot;as cast&quot; pads. Since the castings varied slightly - the thickness of the machined pad varied as well. One &quot;tell&quot; however, is the &quot;lip&quot; on the water pump casting when it bolts up to the block (the distance that the water pump sticks above or below the pad). Since the water pump mounting bolt holes are established from the same locating pads as the head face, there should be some consistency in &quot;lip&quot; area. I've seen some &quot;original&quot; stamps where the water pump sticks up way above the pad stamp area. It's not a 100% &quot;tell&quot; of a decked block, but certainly bad juju. JMHO
