Old 03-11-2015, 01:49 PM
SS427's Avatar
SS427 SS427 is offline
Default Re: Black L78 1969 SS396 300 Deluxe Post Sedan Found
Great progress Rick.
Rick Nelson
Old 03-11-2015, 01:53 PM
scuncio scuncio is online now
Looks great.
I see you posted a disassembly pic showing the broadcast sheet stuck to the inside of the fender. Were you able to read any of it?
Old 03-11-2015, 04:12 PM
Rixls6 Rixls6 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: scuncio</div><div class="ubbcode-body">Looks great.
I see you posted a disassembly pic showing the broadcast sheet stuck to the inside of the fender. Were you able to read any of it? </div></div>
It was so tar covered and torn that I can't see anything, but haven't tried to clean the tar off.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 03-11-2015, 04:19 PM
Ryan1969Chevelle's Avatar
I remember a thread where someone removed the tar from a build sheet found on the floor of a Chevelle.
I was amazed it came out legible.
Ryan
Old 03-11-2015, 05:07 PM
James Groome posted a good way to remove the tar from a build sheet with before &amp; after pics. I will ping him to respond to this post.
Old 03-11-2015, 06:07 PM
There really is only a small section of the Broadcast sheet there, so after cleaning with Acrysol, I wouldn't expect much info, but I will eventually do it.
Rick
Old 03-11-2015, 10:26 PM
Now the next famous question? When does she go to Body Shop? Frame resto is next, I assume?
Old 03-11-2015, 10:59 PM
I don't have any before pictures any longer.
I will post some of the finished build sheet later.
I used fast lacquer thinner, believe it or not the thinner will not remove the &quot;carbon copy&quot; type of impact printing on the factory sheets.
I first did this back in 2001 and have done it countless times since.
The GTO Judge conv one I did was completely black from tar, I put it on a stack of paper towels then put a few paper towels over the top then set the whole stack on a piece of expanded metal thus acting as a grate, then poured the lacquer thinner through the stack. The paper towels absorbed the tar freed by the lacquer thinner. You will be amazed by how much tar you can remove. I used cheap fast lacquer thinner for gun cleaning you may be able to use acetone with the same results.
Survivors, restored cars, &amp; other photos
Old 03-12-2015, 12:52 AM
Here are some of the judge build sheet... keep in mind this sheet was completely tar stained, it looked like a thin piece of roofing tar paper paper.
I have not fond anything which will remove Rust stains, rust is also VERY acidic and will break the paper down quickly.
Old 03-12-2015, 01:23 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">WOW! I had no idea you were going to do this in your garage?
Looks great! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] [img]<<GRAEMLIN_URL>>/worship.gif[/img] [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Dan </div></div>
Times two...wow!!
