Old 12-28-2022, 10:22 PM
Chuck_Burg's Avatar
Here's the goods Tim... I made cardboard template then got some scrap aluminum and put it in my father in laws brake. Bent it at a 65* angle and drilled some holes for the filter and the pump. I will mostly hardline this to make for a cleaner install. I think it will most likely be a straight old school draw through system meaning the fuel will always be drawn through the pump whether it's on or off. The pump is a Carter 4600HP rated at 50 gallons/hour and 4.5-8psi.
The Following 4 Users Say Thank You to Chuck_Burg For This Useful Post:
69M22Z (12-29-2022), napa68 (12-28-2022), NorCam (06-21-2023), olredalert (12-29-2022)
  #412
Old 12-28-2022, 10:25 PM
Chuck_Burg's Avatar
Originally Posted by R68GTO View Post
Your new dizzy & wire setup is freakin' awesome! Car looks great with the slots!
Thank you! I agree... The slots just give it such a sinister look. All business
Old 12-28-2022, 10:26 PM
Chuck_Burg's Avatar
Originally Posted by Crush View Post
This is my 2nd favorite car on here…… just a killer car!!
WOW! Thanks Crush.... Did I mention it drives as good as it looks?
Crush (12-28-2022)
  #414
Old 12-28-2022, 10:52 PM
Crush Crush is offline
My daughter lives near LA. When I’m out there I’ll come by for a spin!!!lol
The Following User Says Thank You to Crush For This Useful Post:
Chuck_Burg (12-28-2022)
  #415
Old 12-28-2022, 10:58 PM
napa68 napa68 is online now
The cool thing about a Day 2 car, they are never done. They most always continue to evolve.
Of course, is any project car ever "done"?
The Following 2 Users Say Thank You to napa68 For This Useful Post:
67since67 (12-29-2022), Chuck_Burg (12-29-2022)
  #416
Old 12-28-2022, 11:22 PM
Chuck_Burg's Avatar
True on all accounts. I understand most of this stuff is way over restored/thought out for most "real" "Day 2" cars but if I lived back then and had the money/knowledge/time to do it like this, this is what it what it would've been
The Following 6 Users Say Thank You to Chuck_Burg For This Useful Post:
69M22Z (12-29-2022), Crush (12-29-2022), dykstra (12-29-2022), napa68 (12-29-2022), NorCam (06-21-2023), olredalert (12-29-2022)
  #417
Old 12-29-2022, 02:45 AM
Perfecto!! and unless my eyes are just seeing what they want to....there's an old small diameter Coors can around that coil??
Old 12-29-2022, 03:28 AM
Chuck_Burg's Avatar
Yes indeed, a genuine old timey coors can!
  #419
Old 12-29-2022, 12:00 PM
69M22Z 69M22Z is online now
Thumbs up
I guess I can't leave well enough alone.
When I was restoring the car I purchased some nice Packard SS550 wires on eBay only to find the vintage style straight boots to be incompatible with the MSD distributor cap so I decided to leave the existing wires my engine builder provided thinking the look would grow on me. As time went on the distributor and wires just became an eye sore for me! I pulled the original distributor (dated July 13th, 1966) out of the original 327 and set out to restore it and put it in my big block.
I found a brand new brown 309R cap and 409R rotor on eBay, both sealed in their original boxes. I was going to go with Pertronix but decided what the hell, may as well keep it super old school and stick with points. I went with Blue Streak DR2371XP points and Blue Streak DR-70XP condenser based on my engine builders 50 years of experience. I removed the original grease and thoroughly cleaned the entire housing, then polished the distributor shaft and points cam with an emery cloth. The shaft bushings were still in very good shape so I didn't replace those. After reassembly, it was getting way too much centrifugal advance so after some math, I determined I needed to shorten the advance slot by about .064". To solve this I applied a small bit of weld to the slot and used a rasp to file the slot to the determined length of .381", compared to the factory .445". The factory slot was giving it 28* of advance, now I get 18* of advance which suits this engine nicely. 18* initial and 36* total which comes in at an early 2,000rpm. I am not using the vacuum advance and went as far as to put some silicon on the point plate to prevent it from advancing at all. I went with the Moroso advance kit, using one of the lightest advance springs and one of the medium springs. I also installed a brand new Comp Cams composite distributor gear.
Now the L88 wires are right at home on this restored distributor and it really looks like it would have back in the day. It performs great as well! With the amount I use the car, I probably won't have to mess with it too much anyway.
Awesome
The Following User Says Thank You to 69M22Z For This Useful Post:
  #420
Old 12-29-2022, 02:47 PM
----The epitome of badness! This great Camaro has everything it should and nothing it shouldn't. No gingerbread allowed.....Bill S
