#461
Love this thread, but...
What I cannot figure out is why you cut up and scrapped the wheeled metal cart under the body. Couldn't that be used for another purpose, or sent to metal recycler?
69 SS 350 convertible (in peices) 69 327 convertible (driver) |
#462
This build is just incredible.
Joe 1969 Camaro Last edited by Z282NV; 10-27-2022 at 04:06 PM. |
#463
![]() Quote:
#464
Correct description of the color! Good on ya!
![]() Don't sweat it, Kevin. When Johnny Tight Lips showed up, we went over the contents of the dumpster and he sorts through what's there and sends metal, cardboard, glass to their proper recycle centers ![]() ![]() Ok, maybe that wasn't exactly Johnny Tight Lips that I chatted with, but the latter part is true. It's actually why I decided to use this guy since he recycles and we loaded it up with cardboard and such too. Cheers Dave |
The Following 2 Users Say Thank You to A12pilot For This Useful Post: | ||
69M22Z (10-30-2022), markinnaples (10-27-2022) |
#465
Been doing some more work and next week I'll start welding the car together from the inside out! With any luck, I'll have a complete car by the end of this month with pics and vids to follow.
Floors have beads run in them for rigidity and I formed the front wheel wells too. Door hinge pockets formed, and various other smaller parts and pieces. Something cool I found after removing the motor were these numbers on each cylinder. I believe they are piston size numbers much like Mopar used letters on the 440 that was in my Super Bee. Those letters were grease pencil on the exterior of the block. Each cylinder is measured and each letter corresponds to a piston size. If the cylinder measures. 004 over, then it gets a letter A. The engine assembler goes to the shelf and gets piston A (a piston .004 over in size from standard) and uses it in that cylinder. .006 over would be a B, and so forth. I'm not quite sure on the actual numbers, but that's the idea behind it. Can anyone confirm this? More next week! ![]() Cheers Dave |
The Following 7 Users Say Thank You to A12pilot For This Useful Post: | ||
67 Nova Boy (11-16-2023), big gear head (11-03-2022), Dave Rifkin (11-04-2022), olredalert (11-03-2022), PeteLeathersac (11-03-2022), RPOLS3 (11-03-2022), Woj (11-04-2022) |
#466
----Dave,,,Just wonder what I'm looking at in the bottom of that last cylinder. Not sand is it?....Bill S
#467
It is actually very fine saw dust, Bill. The walls and pistons were coated in cosmoline which has browned over the years. The block was stored in its original crate and was protected in a bag.
The dust came from building the trophy for the award I'm handing out at MCACN. I just didn't vacuum it up before I took that photo. ![]() Cheers Dave |
The Following 3 Users Say Thank You to A12pilot For This Useful Post: | ||
#468
----Thanks, Dave! I knew there had to be an explanation.....Bill S
#469
Similar markings to the 455 block in Gramma's Firebird, only stamped into the deck surface! I have the GM paperwork somewhere that translated the letter codes into the oversized components.
The Following 3 Users Say Thank You to njsteve For This Useful Post: | ||
#470
Awesome! Nice to know Steve!
![]() Cheers ![]() Dave |
