#41
Good point Dave. I doubt I will ever need to pull one in. I could just back up to the door and unload it into the shop. How tall is a typical one car car hauler?
Looked at this one: https://www.trailersplus.com/Oklahom...S2422LC051698/ Overall height is only 9 foot. I do not ever anticipate having to pull in anything bigger. If it is bigger, it will have to go in the other end of the shop, where I have a 13 foot high door.
#42
I would suggest getting one with the "V" front to cut down on wind drag. plus you get extra room for storing the spare tire etc...
#43
I am not planning to buy an enclosed trailer. Just wanted to see if it would fit in my new doorway.
Measured today, and using the two 16 LVL beams I have, I can go 10' 4" without having to remove the old header, which will make this go a lot easier for me. Thanks for the comments. Promise to add some more updates soon. I am working feverishly to get as much done as possible before Jan. 23. I am having reverse total joint replacement on my left shoulder. Once that one is healed, I need total joint replacement in the right shoulder. Sucks getting old.
The Following 2 Users Say Thank You to Lynn For This Useful Post: | ||
olredalert (12-21-2019), scuncio (12-21-2019) |
#44
Promised more updates on the shop. Not sure how to update this. So much has happened, and thankfully, I changed directions on this. You will see why.
Have to explain the layout of the building. It is 45 feet wide. The East end is square. The West end is not. The South wall runs about 125 feet, and the North wall about 105 feet. So, for you math guys, it is a left trapezoid with one wall perpendicular to the two parallel walls. I had planned on using just the West end as a two bay work space with one lift and a flat bay area. Would have been about 1400 feet, albeit in a bit of an odd shape. The floor was already concrete with virtually no cracks, except around the pole I removed making it a clear span area. The flooring just to the east is the original wood floor (building was used for coal storage in the 1920’s). 2 x 12 joists on 16 inch centers with 2 x 6 flooring planks. Previous owner was driving cars on it, so it was plenty strong. But, I wanted to wall off my work shop area so that I could heat it in the winter. I can stand the summer heat, but not the winter cold. The only ventilation for the crawl space was out to the shop area. You can see the crawl space in the first three pics below. First one is looking East from the North end of my work area. The building has no crawl space ventilation on either side. Well, not DESIGNED ventilation; but plenty of air gaps in the tin siding on the North. It was VERY damp under the wood floor. I mean really damp. I bought a bunch of steel grates to place strategically in the floor and was getting ready to wall that area off. Then I got greedy. Wouldn’t MORE shop space be better? Of course it would. So, the next plan was to remove about 1/3 of that wood floor. I planned to concrete it on the same level as the work area, so that I could store welding equipment, gantry crane etc. and be able to roll them over to the work area. At first, I started pulling nails one at a time. Screw that, get the circular saw, and cut each floor board even with one side of the joist, and just use it as leverage to pull up the floor boards. Fortunately, one of my brothers was able to come over that Saturday and help. After removing about a third of that third of the floor, I noticed something black on the ground under the joists. I poked it with a pry bar, and found it to be a puddle of water. Talk about damp. No, not damp; wet. After removing enough of the flooring and joists that I could access the puddle, I stuck my pry bar all the way in. Didn’t hit bottom. Had my brother hand me a 6 foot piece of conduit; stuck it in. Still didn’t hit bottom. WTH?? We had uncovered a freakin artesian well. Pics below. No wonder it was always so damp under there. Went to Ace and bought a sump pump with float. Pumped it as dry as I could. Two nights later, we got ½ inch of rain. Thought I would go down to the shop and see if there was a couple more feet of water in the well. It was full again, after just ½ inch of rain. I have still not cleaned the well out completely (may find Jimmy Hoffa in there). There are pieces of wood at the bottom that are water logged. No telling what we will find when we finally clean it out. Hoping it was a wishing well. Photos of the well were taken about a week after we removed the flooring on that third. The well is bigger than it looks in pictures. It is 36 inches in diameter. We have since discovered that this building was NOT the first structure on this site. However, it is apparent, they had no building codes to speak of in 1919, or someone just didn't pay attention. They built this building right over an existing well. I have discovered remnants of at least two footings from previous structures. We are less than 60 yards from the rail road tracks, which have been in the same place since before the land run in 1889. So, this may have been used as a spring fed water source for the trains. More to come.
The Following User Says Thank You to Lynn For This Useful Post: | ||
scuncio (12-23-2019) |
#45
Wow, that's cool!! I hope you get somebody local to metal detect the dirt before you pour concrete. You never know!
Mark 1966 L72, 4spd Caprice 1974 Z28, M40 Camaro |
#46
We dug up whiskey bottles, old Coke and Pepsi Bottles, a steam kettle, 5 pistons (approx 5 inch bore) and myriad other odds and ends. Did not sweep with a metal detector.
#47
That is insane! Do you think your building had been previously configured to allow access to that well? I can't imagine they would have just built a new structure over that.
#48
Pretty sure they build right over it. Those joists are typical 2 x 12 from 1919. Slightly thicker than a modern 2 x 12. Very straight grain Douglas Fir with zero knots. I will take a pic of an end cut. You would not believe how many rings per inch. Old growth wood. You would think they would all be rotted from that moist environment, but there was only about 5 % rot.
#49
Those very tight and small rings are defiantly 1st growth timber. I have a few scraps of 1st growth doug fir 4x6's. Interesting.
Mike |
#50
What a treasure trove of coolness! I know this throws a wrench into progress, but what a cool side story for your neat building. Keep us posted Lynn!!!
Sam... ![]() |
