Old 05-28-2007, 04:13 PM
DarrenX33's Avatar
Default Re: 1970-72 Super Stock Meet @ Union Grove
Gladly Rick...
Just curious, are they full size or the same size as we are seeing here? I'm thinking of framing a few for my garage...
1969 Z28
1972 Corvette
Old 05-28-2007, 06:20 PM
Rixls6 Rixls6 is offline
The pics are pretty much the size you're seeing here. You could probably blow them up with photoshop or something like it though. I'll try to make them bigger on my computer and see if the quality holds up.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 05-28-2007, 06:39 PM
ANDY M's Avatar
ANDY M ANDY M is offline
Rick, did you scan these pics? They were obviously taken with a quality 35mm or larger format camera, and if you can scan the negatives, it would be easier to blow up the photos. Using a flash at night means using very high speed film, ASA 400 or better. Very dense quality film designed for larger prints without losing resolution.
Any good scanner can reverse a negative to a positive image, so you can scan the negative at a higher resolution for enlargments than just scanning a print and trying to blow it up. Then you will run into pixalation problems. JMO.
I oftened wondered how the drivers felt about those flash bulbs going off when they were launching. That takes real concentration on the tree!
COPO 9561/9737 M40 X11D80
13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22
Old 05-29-2007, 03:59 PM
Thanks Andy for the info about scanning the negatives. I wasn't the one who scanned these originally, so I'll contact the guy I got them from.
I did blow these up on the computer and they will go bigger without too much pixelation, but a negative scan sounds like it would work better.
Rick
