Old 01-05-2010, 12:02 PM
kwhizz kwhizz is offline
Default More L-89 Nova Info
"The Tonawanda engine plant kept VERY accurate records on engines built during each model year. These "Summeries of Engines Built" list EVERY engine we built by assembly number and description. This number crossed over to a suffix code so from them I could determine how many of each SUFFIX CODE we built. Sometimes, as in the case of the L-89 engines built, I had further records. In these cases it was "engine canceled, not replaced" and then a date.
In the case of the L-89 engines in 1970, in October 1969 the L-89 396 option was canceled, not replaced. As far as the LS6/L89 NONE WERE BUILT. Period. In model year 1970 NO aluminum head LS6 engines were built. In 1971 there were 200 LS6 engines built and put into Corvettes, ALL were aluminum head (due to the lowered compression ratio).
I've spent many years researching big block production (ALL big blocks). I'm always open to new information, DOCUMENTED AND IRRIFUTABLE. But if anyone wants to contradict me they'd better have better records than I do!.
Sorry if this sounds "hard", but it's late and I'm tired. If you need anything more feel free to Email me.
Fran Preve"
Just quoting what I was told by Fran. As many know, he was a plant manager for many years at the Tonawanda plant and had aquired all the records for a period of time including the late 60's and early 70's. To my knowledge his widow now maintains these records. R.I.P. Fran
This info was in the Clements L-89 Chevelle thread and shines a little more light on the Production Dates for the L-89 option........Seems the Engine combo was dropped in October 69............The Black 1 of 1 car was built in the third week of March...........Another piece of the Puzzle.....Doesn't seem possible .......... .
Ken
Attachments - The Supercar Registry 437428-tn_IMG_1231_edited.jpg 437427-tn_IMG_1232_edited.jpg
Old 01-05-2010, 04:16 PM
ron67 ron67 is offline
Default Re: More L-89 Nova Info
Ken, You are the MAN!
Ron
63 Chevy II convertible SS
63 Pro-street Chevy II
66 Chevy II SS L-79
67 # match 427/390 Corvette Rdst
86 Corvette 30k miles
Old 01-05-2010, 05:28 PM
GreenLS6 GreenLS6 is offline
Which heads where used on those 70 l89 chevelles (396 engines) the books say 074's but I've never found the piston. did 842's carry over till the cancelation in late (OCT).69 ???
Tim Clary
68 RS/Z28
69 Olds Cutlass S
70 Chevelle SS LS6
70 AMX 390 Go-pack
71 Torino GT 429cj
Old 01-05-2010, 06:35 PM
Steve Shauger's Avatar
Administrator
Yes
www.yenko.net
www.vintagecertification.com
Old 01-05-2010, 07:34 PM
92646 92646 is offline
Ken with this information is it possible that a 1968 or 1969 L89 Nova could have been built?
Old 01-05-2010, 07:53 PM
old5.0 old5.0 is offline
69 seems most likely of the three, doesn't it?
Old 01-05-2010, 07:55 PM
If the L-89 was offered back then Fred Gibb would have had them on the 68 nova.
Jake is my grandson!!
Old 01-31-2010, 03:07 AM
Guest
Posts: n/a
Is this the right place to get info on my 1969 L89 Corvair? I know that a certain run of Monza COPO cars were built, but I hear that my four door hardtop is the only 1 of 1 ever built. My friends tell me that the only thing more desirable is the rare 348-powered 1961 Rampside model, but they could be wrong. I see you folks know a lot about things like casting numbers and compression ratios too. I'm going to rebuild my L89 396 and to get the compression ratio the same as that 1970 Nova you guys talk a lot about, I was thinking that maybe if I get a couple of boxes of cut off wheels for my Makita angle grinder I could take the domes off the pistons? Isn't that how you do it? Anyway, when I git 'er done, can I get some of you guys to double check the numbers? That way, when I take it down to the auction, I can get big money for it. How much do you think she'll bring?
‘Sled
Old 01-31-2010, 05:07 AM
SSRSBOB SSRSBOB is offline
Also had secret L89 option for the '69 Z28. Special aluminum heads with screw in studs and BIG valves. Very rare!
Bob
