Old 03-29-2018, 02:25 AM
Originally Posted by Steve Shauger View Post
Oops! This is the second instance that I'm aware of the Polyglas may have been used. Two data points is a start but certainly far from conclusive.
Turns out the second instance Steve referred to is the same one Rusty just gave Jerry credit for. So as of now we have maybe 1.
The Following User Says Thank You to Charley Lillard For This Useful Post:
camarojoe (03-29-2018)
  #52
Old 03-31-2018, 02:40 PM
William William is offline
The alleged OE '69 Camaro Polyglas spare has a couple problems.
It is not balanced and does not have the paint dot at the BB welded to the rim. Those are indications it was not installed in production.
I recall discussing this with JM. I believe the car had docs and PL4 was not listed.
The Following 3 Users Say Thank You to William For This Useful Post:
camarojoe (04-01-2018), Jonesy (04-03-2018), m22mike (03-31-2018)
  #53
Old 03-31-2018, 04:00 PM
Back to ground 0.
The Following 2 Users Say Thank You to Charley Lillard For This Useful Post:
  #54
Old 04-03-2018, 08:21 PM
Jonesy's Avatar
Jonesy Jonesy is offline
So my 69 Camaro SS, LA Built in Nov 68 with IF wheels and white lettered tires came with Goodyear wide treads?
Old 04-03-2018, 10:17 PM
That would be correct if it came with Goodyear tires. Would look like these:
As you can see from this period photo, some came with Uniroyal Tiger Paw F70x14 RWL tires
Old 04-04-2018, 03:42 AM
Do you have the build sheet for the car?
Give me a call, I will be happy to help!!
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 04-04-2018, 06:37 PM
Jonesy's Avatar
Yes I have the build sheet.
Heres whats in the boxes that refer to wheels and tires
285 COLOR - 55
287 SIZE –IF
288 – 1 DOT
289 TIRE BRAND – 1 DOT
HIGHWAY (OR COPO FRONT) TIRES
290 QTY – 5
292 SIZE F70 14
RTG – 4
PLY- 2
MAT – 1 DOT
WALL – Z
TUBE – BLANK
SPEC – BLANK
SPECIAL REAR TIRES
296 SIZE – 5 DOTS
RTG – 1 DOT
PLY – 1 DOT
MAT – 1 DOT
WALL – 1 DOT
TUBE – 1 DOT
SPEC – 1 DOT
298 – 1 DOT
Old 04-04-2018, 11:46 PM
The PL4 option was released early April '69. Your car could not have been built with RWL FG Belted tires.
Old 04-05-2018, 03:05 AM
Very true... The question is then, what stripe color or RWL?
1969 Hurst/Olds
Rusty Small
