Old 06-08-2015, 05:06 PM
69 Post Sedan's Avatar
Default Re: Grandfather's 68 SS Camaro.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JRC99</div><div class="ubbcode-body">Having done a bit of research on the C427X intake (already knew it was a 70's piece, not to mention Motion used them), most people seem to run them with a 780 (or larger) carb. Is a 750 not enough for these? I have heard they flow extremely well. </div></div>
If you're looking for the &quot;Day 2&quot; look....the C427X in a good candidate. If you're fine with the stock look, the factory &quot;163&quot; intake actually works better than the C427X. I believe it was someone on here that did a comparison back in the day and the Edelbrock didn't perform as well as the factory intake.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 06-08-2015, 07:59 PM
JRC99's Avatar
JRC99 JRC99 is offline
I plan on keeping the C427X purely for the Day 2 look.
My cars, passed down by my grandfather:
'68 Camaro SS (454/TH400, possible L78/M22) LeMans Blue, black deluxe interior, black vinyl top. 3.73- mostly Day 2.
'89 Mustang GT- 3.55, subframe connectors, muffler delete, and a couple other minor mods. Exactly as he wanted it, so how it shall stay
Also:
1995 Ford F-150 XL
2004 Dodge Ram Hemi GTX- #192 of 433
Ain't no fun in viewing your car as an 'investment'. Get out there and beat on it!
Old 06-09-2015, 02:03 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JRC99</div><div class="ubbcode-body">I plan on keeping the C427X purely for the Day 2 look. </div></div>
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 06-09-2015, 02:22 AM
JRC99's Avatar
By the way, what's the best way to clean it without pulling it off the car? The grime and cruddyness ruins it.
https://www.yenko.net/ubbthreads/pics/use...746231903_11803
Also:
1995 Ford F-150 XL
Old 06-09-2015, 03:00 PM
I spray carb cleaner. Maybe try Simple Green or Purple Power first and see if that will work. Just be sure to wash it off thoroughly and cover up the carburetor and anything electrical.
Kurt
Old 06-19-2015, 12:44 AM
JRC99's Avatar
I've asked my grandfather about the car's hatred of running right (loads up like there's no tomorrow, and good Lord, this thing just falls flat on its face under acceleration) for the umpteenth time, and he suggested something quite plausible: Carbon buildup. The motor doesn't look like it was ever taken apart. I know seafoam is supposed to clean it up. Wondering if I should try it.
Also:
1995 Ford F-150 XL
Old 06-19-2015, 05:22 AM
I'd look more in the direction of tune up type stuff, ignition, and carb. I'm not sure what type of carb it is but falling on its face could well be a faulty accelerator pump from sitting.
Jason
Old 06-19-2015, 07:31 AM
JRC99's Avatar
Not that. Carb has been replaced, spark plugs replaced, cap and rotor.Still does it.
Also:
1995 Ford F-150 XL
Old 06-19-2015, 02:08 PM
scuncio scuncio is offline
Listen to Jason. Most carbs need work right out of the box. Look into it.
Old 06-19-2015, 03:06 PM
JRC99's Avatar
Wasn't right out of the box actually. It works brilliantly on the Chevelle. It's gotta be something else.
Also:
1995 Ford F-150 XL
